Tire Stretching Help
So I just bought a set of wheels 19x9.5 19x10.5 +35 offset and was wondering what tires I can run with the least amount of stretch. I was initially thinking of 225/35 for the front and 245/35 for the rear. After some discussion with Joseph (Josephdoc) he said that might be a bit stretch. I have a lot of dips/potholes/etc. around my area. Also I want to keep my initial height right now. Some pics of my height if it helps:
I am somewhat tucked with my oem wheels with about inch from the outer rims. Thanks in advance
I'm no guru in wheel fitment, but your gonna need fender mods with those specs and ride height.
Ask the same question in this thread, you'll definetly get your answer.
https://www.clublexus.com/forums/is-...tart-here.html
I bought some LE37. So with that setup it won't be overstretched right? I am currently debating on 225/35 or 235/35 up front. Did it rub after rolling it though?
I didn't do any fender work on the front with the 225s. The fender liner went to hell, but that's probably going to happen regardless. It wasn't too bad of a stretch though. I drove in LA just fine with that setup. The rears did rub after shaving, but that was with 5mm spacers.
Oh no no gap, I hate gap. 225/35 it is then.
