is there any way to... [get LED DRLs on older model years]
do get the led lights under the headlights like the 2011 is350's on an older model. im not talking about the fog lights. the lights that stay on all the time
Those are called Daytime Running Lights (DRLs) - on the earlier 2IS, they're halogen bulbs on the inside of the low beams, and on the later ones they're LED strips below the low beams.
There seem to be two options for this. There are tons of aftermarket LED strips you can install either on or inside the headlight, and they're of different qualities and prices. For what I've seen, they look roundly terrible. They're typically plastic strips with LEDs inside and they just look crap.
The other, more expensive option is to buy the 2011 headlights and retrofit them to your earlier 2IS. This will be much more expensive but will give you exactly what you're looking for, instead of something that looks like you got it at the bargain bin at Autozone.
Keeping it Real
They'll fit, but you also need to rewire them slightly, however I believe Sewell actually sells a plug 'n play kit to install them on older 2IS models.
Halogen to 2011 HID: http://is.sewellparts.com/accessorie...2008/2411.html
Pre-11 HID to 2011 HID: http://is.sewellparts.com/accessorie...2008/2400.html
Jeff
Jeff
Keeping it Real
I don't know how much confirmation we have on that yet. According to the NCF (New Car Features) book, yes you lose Bi-Xenon. The NCF is usually quite accurate about things of this nature, so I would tend to believe it. Various other information still lists them as Bi-Xenon, but most of that is likely a missed carry-over description from 2010.
I don't have factory HID's on my 2011, or I'd check myself.
Jeff
Jeff
