5mm slip on spacers??
anyone on here running 5mm slip on spacers? i know 3mm will work but i was curious to see if anyone is running 5mm with 0 issues. are there enough threads on the stock/oem lug studs? atleast 7-8 turns?
I know some people on here are running 5mm spacers without extended studs. I personally think if your running anything over 3mm you should just get the extended studs to be on the safe side. You might be fine running a 5mm without extended studs, but there's still a chance...and its better than losing a wheel on the highway
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
Ichiba states that for a 12mm 1.5 wheel stud you need at least 6.5 turns.
In the past I have experienced vibrations from spacers only when I used some that were not hub centric. My current ones are 15mm up front and 20mm in the back and they are hub centric and have no vibes.
4play4dr
Suspension and Brakes
21
07-07-15 03:20 PM
