Tire is separating?
Old 09-19-11, 12:10 PM
HAiS250
HAiS250's Avatar
Exclamation Tire is separating?
I noticed that the side wall on my tire is separating. Anyone know what caused this?
Old 09-19-11, 12:26 PM
TheSenator
TheSenator's Avatar
Does this go all the way around the rest of the tire? How's your air pressure? What's the manufacture date on the tires?
Old 09-19-11, 12:31 PM
whitebeast
whitebeast's Avatar
it's just wheel protection lip so nothing wrong. It's normal
Someone correct me if i was wrong.
Gville350
Gville350's Avatar
Weathering, tire age, and LOW air pressure will aid in that type of cracking.
Old 09-19-11, 12:37 PM
TheSenator
TheSenator's Avatar
+1.
Hence those questions....I'm gonna bet on weathering/tire age if it does not circumvent the tire. If it does, I'm going with low pressure.
Old 09-19-11, 12:39 PM
HAiS250
HAiS250's Avatar
It doesn't go all the way around and the tire pressure is good. I have to look at the manufacture date when I'm on break.
Can someone confirm this? If not, I'll get a new set of tires or something
Thanks for the info
Old 09-19-11, 12:47 PM
MyIS350G
MyIS350G's Avatar
Could be it, what brand tires are they?
Old 09-19-11, 04:46 PM
UrHookUp
UrHookUp's Avatar
Could be from curb or pot hole.
Should take it to a tire store that is a reseller of that brand tire.
Old 09-19-11, 04:58 PM
KillaIS250
KillaIS250's Avatar
Nah that's not the wheel protection lip that's cracking. I had something like that before, happens when you drive on low pressure, or have low tire pressure and let the car sit. The weight of the car damages tires if you've got low pressure.
Old 09-19-11, 06:49 PM
whitebeast
whitebeast's Avatar
I take it back after i a good look at your picture clearly (cannot see it well this morning)
Old 09-19-11, 08:53 PM
birador
birador's Avatar
aged of tire plus running with a low pressure tire causes cracks on sidewall,that's dangerous,consider replacing it before its to late..
Old 09-19-11, 10:39 PM
Lil4cyl
Lil4cyl's Avatar
Must replace asap. dangerous.
Old 09-20-11, 08:52 PM
HAiS250
HAiS250's Avatar
I checked my tire pressure and it's at 32 psi. Is that low?
Old 09-20-11, 10:24 PM
Squirrelz
Squirrelz's Avatar
I keep my tires at 37-38 PSI cold.
Old 09-20-11, 11:04 PM
Sango
Sango's Avatar
Tire advise as per alignment tech person for my car.
40 PSI fronts
36-40 PSI rears
Quick Reply: Tire is separating?
