Tire Rotation Question
Old 09-23-11 | 07:59 PM
PapaCat's Avatar
PapaCat
Default Tire Rotation Question
The manual for my 2011 IS250C states that the tires should be rotated at 5,000 "if appropriate."
My dealer refused to rotate them because the front tires are a different size from the rear tires. I explained that all they have to do is switch the tires on the left to the right side, and vice versa. Again, they refused. Any thoughts on this kind of treatment from the dealer you purchased a $49,000 car from?
Naturally, I would not accept their answer, and wrote a complaint letter. Eventually, the called me back and did the rotation. Am I correct in insisting the tires be rotated in this pattern (left to right, and right to left)? Maybe I'm missing something?
Old 09-24-11 | 12:07 AM
Kurtz's Avatar
Kurtz
If the tires are directional then you just forced them to screw up your tires.
If they're non-directional then yeah, left/right on the same axle is fine to rotate.
(I've no idea what tires are shipping OEM on an '11 250C so can't say if they're directional or not)
Old 09-24-11 | 05:25 AM
Bichon's Avatar
Bichon
Super Moderator
Technically you can rotate directional tires from side to side if you are willing to dismount them from the rims and flip them around, but in the real world I don't know anyone who does so.
Old 09-24-11 | 06:14 AM
PapaCat's Avatar
PapaCat
The tires I'm referring to (2011 IS250C) in my post are non-directional. There's no need to dismount them, so I really wonder if the dealer was just trying to save time and/or money. And possibly, hope my tires wear out a/s/a/p so they can sell me a new set.
Old 09-24-11 | 08:10 AM
birador's Avatar
birador
if not directional yeah you can ask to swap it left to right/right to left both front and rear since it staggered,i don't know why they refusing to do it at first.
Old 09-24-11 | 08:49 AM
WIZARD1325's Avatar
WIZARD1325
how can you tell if there directional or not?
Old 09-24-11 | 09:12 AM
iRock's Avatar
iRock
whats the point on swapping from left to right?
Old 09-24-11 | 11:34 AM
birador's Avatar
birador
uneven wear of tire due to bad alignment....
Old 09-24-11 | 12:00 PM
07Lex350's Avatar
07Lex350
I was at the dealer not too long ago, noticed that the new ISx50 were running 225 in the front and 255 in the rears? I assumed they would be running 255 all around, I'm not sure what year Lexus decided to this. No rotations to front and back and directional. Headscratcher...
Old 09-24-11 | 12:15 PM
ISBU's Avatar
ISBU
I rotate my tires from left to right to get even tire wear and prevent tire cupping which causes noise. Tire manufacturers are making more non directional tires nowadays. Directional tires have markings on them left or right on the sidewall.
Old 09-24-11 | 12:19 PM
tenspeed's Avatar
tenspeed
People tend to take left hand turns faster than right hand turns. Right side tires are subject to more pot holes and road hazards. Right side tires tend to lock up sooner due to less weight and more grit on the road side.
Old 09-24-11 | 12:20 PM
LDNN's Avatar
LDNN
This was my first impression, too.
Old 09-24-11 | 12:22 PM
tenspeed's Avatar
tenspeed
The early IS-F's have four different rims.
Old 09-24-11 | 12:35 PM
Sffd103's Avatar
Sffd103
Fire Slayer
aren't some IS's equipped with wheels that need to be placed a certain way too?
Old 09-24-11 | 12:37 PM
Kurtz's Avatar
Kurtz
Far as I know RWD models have always been that way on 18" wheels. (17s are also staggered but use 225 front and 245 rear instead of 225/255)
It's only AWD models that don't come with staggered wheels.
