Hi,
Would appreciate fellow CL members knowledge regarding GFX rear lip installation. Is a DIY project or take to a professional? How much does it normally cost to have this done? Please help.
yea i was thinking of doing the same thing to my is... pretty sure you can do it yourself if you ordered from sewell then you can download the pdf file that shows you the instructions. otherwise you could always get REALLY strong double sided tape lol
remove the brackets. Add extra double sided tape if necessary. wash and clay the areas that the lip will fit onto. Wipe off area with rubbing alcohol and let it dry. Spray adhesion promoter to the area and let it dry to a tacky feeling. Apply the lip. Done.
