Help!? Hood does not align with fender.
Old 09-24-11, 08:58 PM
vi3t80y
vi3t80y's Avatar
Default Help!? Hood does not align with fender.
Ok... I still can't figure out why one of my fenders is higher than the hood so basically doesn't align while the other one seems to be perfectly fine besides that one part where it's a tiny little bit lower.. So my question is...
Is there a way to adjust the hood height wise like lower or higher it on sides or are these supports not being quiet the same on both sides affect the height of the fenders in any way?
Old 09-24-11, 09:08 PM
whitebeast
whitebeast's Avatar
Pix will help you better
Old 09-24-11, 09:16 PM
Gladius
Gladius's Avatar
I was thinking the same thing....lol
Old 09-24-11, 09:23 PM
vi3t80y
vi3t80y's Avatar
i will take picture tomorrow.it like when i feel finger from the hood to fender line on the passenger side it smooth and even but on the driver side its not even and the fender line higher than the hood line 1 inch.
Old 09-24-11, 09:33 PM
rookieIS
rookieIS's Avatar
there are two rubber things that the hood sits on under the hood which you can turn to adjust the height (its on the plastic engine cover). i'm not sure what it is called, but it worked for me. i'll try to find a picture of it.
Old 09-24-11, 09:36 PM
vi3t80y
vi3t80y's Avatar
would you take some picture if you can.thanks
Old 09-24-11, 11:16 PM
nmpeter
nmpeter's Avatar
I have the same problem. I thought it was from me rubbing the fender.
Old 09-25-11, 05:55 AM
tjschraf
tjschraf's Avatar
i have the same problem, the rubber stoppers do help to make it fit, but i assume you have the same problem as me where you need to slam your hood in order for it to close (then the stoppers go down).
Old 09-26-11, 02:18 AM
MrBBQ
MrBBQ's Avatar
Try adjusting these rubber stoppers by twisting them. Counterclockwise=up, clockwise=down. The front corners of the hood rests on this to level it with the fender.
Attached Thumbnails Help!? Hood does not align with fender.-imag1118.jpg   Help!? Hood does not align with fender.-imag1117.jpg
Old 09-26-11, 08:17 AM
vi3t80y
vi3t80y's Avatar
Thanks really much guy.it even now.i was worry about something wrong with the frame because i did hit my car really bad on that side and bend and flow the tire last coupe week.Thanks again
Old 09-26-11, 11:25 AM
KillaIS250
KillaIS250's Avatar
I had that same issue, then someone pointed out at a meet that you can adjust it lol. It's one of those things nobody else really notices you but you and it bugs the crap out of you when you look at it...haha
Old 09-26-11, 12:39 PM
whitebeast
whitebeast's Avatar
Glad everything is ok now.
Old 09-26-11, 06:04 PM
MrBBQ
MrBBQ's Avatar
Oh you didn't mention your car was hit.. that's a different story where other factors come to play such as did the bodyshop do a good job replacing/fixing things back or close to factory spec?
Old 09-26-11, 06:20 PM
vi3t80y
vi3t80y's Avatar
i mean i hit on corner and bend my wheel and tires.i have replace wheel and tires on that side.i was worry the hood isnt even with fender because i hit the corner in that side.i check and see nothing wrong and there is no scratch on fender and headlight.im not worry much now because it had been fix.
Old 09-26-11, 08:08 PM
tenspeed
tenspeed's Avatar
The bumpers at the outer edges adjust the height to the fender. Moving the latch in the center adjusts the gap across the front.
Quick Reply: Help!? Hood does not align with fender.
