Baffling delima/Question
08 IS350
I could have sworn when I shut off my car and open the door at night the door slits turn on...
After installing my Door LEDs I notice that my Slits only come on when the button on the roof labeled (door) is selected. So what I am saying is the slits now only come on when my dome light is on. Did I program it to do this by mistake when I took off my door panel?
The only thing I did was program the window motors back again because when I disconnected the window switches the windows wouldn't roll down..So I held it for 5 seconds and they went back to normal...how does everybodys door slits activate?
you should have connected the wires to your footwell lights
I was thinking about your solution a few months ago and the more I thought about it and observed the behavior of the footwell LEDs, the more I liked that as the preferred behavior for the doorcup LEDs - so I rewired them. I tapped the footwell LEDs, and ran the wire through the fender and door, into the door panel up to the door cups. I did this on both passenger and driver sides.
Although the "mismatch" in behavior didn't really bother me (you have to lean forward to see the driver's side LED anyway), what I really liked was the dimming behavior when you shift from P to D. In P the LEDs are at 100% brightness, when you shift to any other position they dim about 50%. It's a lot more work to wire them this way but IMO well worth it - the dimming effect it provides is very classy. Thanks sinister2c!
I'll see if I can take some night shots to give all those asking an idea of what it looks like in the dark.
Javier
Javier
kubakj
NX - 1st Gen (2015-2021)
04-23-19 01:04 PM
