need advice on removing LCA bolts
Old 09-30-11, 10:02 PM
RDIS250AWD
RDIS250AWD's Avatar
Default need advice on removing LCA bolts
I'm trying to put springs on my car right now and the lca bolts will not budge.used a Breaker bar pb blaster and that didn't do anything. Can anyone help me out w this?
Old 09-30-11, 10:11 PM
MrBBQ
MrBBQ's Avatar
Yea, those are tight. I used an impact gun but not everybody has one of those. I would be wary of using a blowtorch to heat it up because of the bushings.
Try using a pipe inserted into the breaker bar to increase it's length. Yea, kinds ghetto but it has gotten the job done in the past when I lacked more tools.
Old 10-01-11, 12:48 AM
RDIS250AWD
RDIS250AWD's Avatar
Thanks bud did all that too still no luck
Old 10-01-11, 03:46 AM
whitecel
whitecel's Avatar
Use a thicker and longer bar. If it wasn't for my impact gun, I would use the long handle of the 3 ton craftsman jack attached to the 1/2" wrench.
Another option could be to try loosen the nut side rather than the bolt side
Old 10-01-11, 06:15 AM
Gville350
Gville350's Avatar
IR 1" impact ftw!
Old 10-01-11, 07:24 AM
RDIS250AWD
RDIS250AWD's Avatar
Yep tried all that and failed. I'm worried I'm gonna break the bolt. Thanks guys. I ended up putting the car back together. Gotta find a shop to do it now. Guess inmate be 4x4-ing for a few more days
Old 10-01-11, 07:40 AM
is150
is150's Avatar
For the price of having a shop do the spring install you could probably buy yourself a compressor and impact wrench.
Old 10-01-11, 09:02 AM
RDIS250AWD
RDIS250AWD's Avatar
I have a compressor and impact wrench. Prob was two lca bolts on one side wouldn't budge. And one on the other side wouldn't budge either. I used a impact wrench breaker bar whole can of pb blaster and still no luck. So yeah salt from the winters here in Ohio must have really seized that on. My only options really is to cut the bolt and that's even a pain plus I don't have the tools to cut nor the patience. So yep shop it is
Old 10-01-11, 09:06 AM
Gladius
Gladius's Avatar
I would do the same thing.....better safe than sorry.
Old 10-01-11, 09:13 AM
supadelish
supadelish's Avatar
I soaked my bolts with liquid wrench and just used my ratchet with the jack handle over the end and through some muscle on it...
You could have someone else grab the bolt and go the opposite direction of what your turning, that will help you break it loose.
-- edit just saw you were from Ohio - yeah... good luck, i had issues years ago with breaking the bolts on my integras exhaust and no chance after a few Ohio winters those *****es were SEIZED for sure!!
Old 10-01-11, 11:09 AM
RDIS250AWD
RDIS250AWD's Avatar
Thanks for the info bud
Old 10-01-11, 11:28 AM
dsage
dsage's Avatar
righty tighty lefty loosey?....try the lefty lossey part. haha
Old 10-01-11, 11:29 AM
RDIS250AWD
RDIS250AWD's Avatar
^useless response
Old 10-01-11, 11:39 AM
dsage
dsage's Avatar
^useless response
not always... i was kidding and im sorry i hurt your feelings
Old 10-01-11, 11:56 AM
RDIS250AWD
RDIS250AWD's Avatar
Didn't hurt anything. Stupid responses just aren't needed when people are tryin to seek help on car forums.
Quick Reply: need advice on removing LCA bolts
