Larger Rims affect acceleration?
Old 10-10-11 | 04:02 PM
Dean8788's Avatar
Dean8788
Default Larger Rims affect acceleration?
I was looking to upgrade my standard 17's to 18's will I notice a difference in acceleration?
Last edited by brociouz; 10-10-11 at 04:17 PM. Reason: Changed thread title to read "acceleration" instead of "speed"
Old 10-10-11 | 04:06 PM
brociouz's Avatar
brociouz
There will be a difference, but it's unlikely that you'll notice. In fact, if you upgrade to lightweight wheels you might actually see an improvement. Just make sure you choose your tires to closely match the OEM rolling diameter.
Old 10-10-11 | 04:18 PM
Dean8788's Avatar
Dean8788
Any paticular brands to focus on that offer light weight wheels?
Old 10-10-11 | 04:21 PM
brociouz's Avatar
brociouz
In general, forged wheels are your best bet for strong and lightweight. Specifically, Gram Lights, Weds and Volks come to mind. Strasse also has some interesting manufacturing techniques where they hollow out parts of the wheel to reduce weight.
Old 10-10-11 | 04:34 PM
Dean8788's Avatar
Dean8788
Lastly any idea how much IS250 17' wheels weigh? Thanks for all the advice would be completely lost otherwise
Old 10-10-11 | 04:37 PM
Sango's Avatar
Sango
Yep would be a difference.
Ride a bicycle with a set of size wheels, then change them with a different one, you would be able to feel a difference there. To a car, well not really but you know, if a car had feelings!! ha ha!
It's pretty much what brociouz mentioned.
Oh yes, Work wheels good too!
Old 10-10-11 | 04:38 PM
rookieIS's Avatar
rookieIS
OEM wheels are engineered and tested for the car's performance, anything other the stock ones will affect the drivability.
Old 10-10-11 | 04:40 PM
Sango's Avatar
Sango
Like ^ OEM steel wheels?
Old 10-10-11 | 04:43 PM
Sffd103's Avatar
Sffd103
Fire Slayer
How about...what are you trying to achieve? Look better only? Be lighter? Or both?? Usually larger wheels that are lighter are quite expensive. I'd say finding out what your objective is the first thing you should do.
brociouz's Avatar
brociouz
I've read that the stock 17" 10-spoke wheels weigh about 27 pounds, but don't quote me. I also read that the stock 18" wheels are about 28.25 lbs. in the front, 30 lbs. in the rear.
Old 10-10-11 | 04:47 PM
Dean8788's Avatar
Dean8788
Bit of both really to be honest. 17's look lost in the lexus's massive arches.
Old 10-10-11 | 04:49 PM
brociouz's Avatar
brociouz
As they say in the engineering community: Strong, Inexpensive, Lightweight. Pick two.
Old 10-10-11 | 04:50 PM
Sango's Avatar
Sango
I'm trying to find that information out too because my new car - I am planning to get Work wheels in 18" retaining OEM spec or going 8.5" front and 9.5" rear and moving the offsets accordingly to retain OEM like offset but but want to know the the stock's existing weight to compare to.
Old 10-10-11 | 04:51 PM
Sffd103's Avatar
Sffd103
Fire Slayer
I'd say go 19's and lower it.....done!
MAAAAAYYYBBBEEEEE!!
Old 10-10-11 | 07:02 PM
istarzan's Avatar
istarzan
Won't increasing the diameter of the wheels throw off the odometer? Looking to get 19's while keeping stock sidewall height.
