VLED DRL Help Please...
Great Deal Guru
I am lost with this mess.
Bottom line if I want to get rid of that ugly yellow light from OEM DRL's and I owe an 06 IS350
but want to replace it with the brighest LED bulbs what do I need to buy?
Harness? No harness, Module? No Module?
Also, can I just buy the module from VLED and use it with some other cheapo same type but china LED version ?
^ If you want the brightest, you'll want the older 28-LED style LED DRL, which requires a relay harness AND module. The other option is the newer 4-LED style LED DRL, which requires only a module, that tucks into the area behind the moisture shield, no drilling required. It's rated to be half as bright.
Not sure if "some other cheapo same type" would work properly since it depends on the power draw. Anything under 7.5W should be okay.
Yes and can you also update with photos. I want to see how they look compared to the old 28LED bulbs first. So I'm assuming the disclaimer can be ignored and used with the newer 4 LED bulbs? Thanks.
Yes.
