Led lights interior
Led lights interior
Hi, I was wondering if someone could tell me where/what kind of bulbs to buy for a 2011 250. I want to change the front and rear dome lights (door open/close), the 2 front door lights (sides of each door), puddle lights, and the 2 vanity lights in the front to white led but I was wondering if there was a way to match it to the stock leds (map lights?) Thanks!
They match the stock ones color wise.
http://www.precisionled.com/lexus-is...erior-pkg.html
Check out my post in this thread.
https://www.clublexus.com/forums/is-...cisionled.html
The owners manual does not list the interior lights. It mainly lists the exterior lights - but even so they use their own parts numbers which makes it difficult to find LED or aftermarket bulbs to the unsuspected unless one already knows what the industry standard numbers are.
The numbers they should be using, should be the industry standard numbers. The way one can find out is by looking at the bulb phyiscally since they should be labeled there.
Since I bought my LED's for my interior, here is the break down of what you're looking for.
Front dome lights, doors, vanity, exterior mirror puddle lights and reverse lights - T10 http://www.jlclightings.com/ProductD...Code=SKU%5F011
Rear dome lights and trunk - D31 http://www.jlclightings.com/ProductD...Code=SKU%5F042
Should be a close match to the map lights if not perfect.
Talk to forum vendor "Auto Design". Those links above are from his site since I purchased LED's from him last week. He gives discount to CL, and to take advantage of this, send him a PM.
If you're trying to match the reading lights, 5000K is what you'll want. You can check out this thread for what specific type of LED should be in each location: https://www.clublexus.com/forums/is-...de-w-pics.html
