Xm radio question
XM TUNER KIT
I know the tuner kit made for my car is a 86180-0W030
I also know that it was replaced with a86180-0W031 which also with my car
My Question is would a 86180-0W032 work and fit in my 2008 IS350? With the (86100-0W220) Harnest?
check out www.vaistech.com they make a Sirius and XM Direct Tuner into your OEM system. Will work on nav and non nav units.
The VAIS one requires taking the dash apart to plug into the head unit, and then either taping up an aftermarket antenna somewhere, or buying an additional adapter and running a wire all the way back to the trunk to plug into the shark fin there.
Only reason to not use the OEM one is if you can't obtain one (which is an increasingly likely event anymore)
Chuck W.
02-23-08 02:14 PM
0w030, 861800w030, 861800w031, 861800w032, compare, es350, is250, lexus, lx470, module, number, part, pn, radio, xm
