Rims IS350
I own a 06 Crystal White IS350 RWD...I've been searching for weeks which rim to buy for my car... I have installed the BC Racing so the car is like 2" drop...it 's still very difficult because at first I though on buying the f-sport rims but after looking for several weeks I have a list of rims that I still deciding which one to buy. I want dark color like gun metal or black mate:
- F-sport Rims
- Volk GTS Phamton Edition - but is pretty expensive..
http://img18.imageshack.us/img18/9489/gtsphantom002.jpg
- 5 Axis super hiro
http://www.axiswheels.com/content/wh...iro_silver.jpg
or
http://www.axiswheels.com/content/wh...super_hiro.jpg
- TE37 - pretty expensive
http://www.flickr.com/photos/wheelsto/3386875870/
Also soon I will paint my calipers which color do you recommend to paint for gunmetal rims or black rims...I am between red or blue.
- F-sport Rims
- 5 Axis super hiro
or
Depends what look you are going for. If you want a storm trooper kind of look, i would go with the Axis super hiro. They aren't too flashy and have a good sports feel. If you have your windows tinted it will look sick with the Crystal White.
As for your calipers, it seems as if red tends to be the most popular regardless of the car. Blue is a little less common and would be a little more subtle especially with the Crystal White. But really a preference call. Again all just my opinion. Good luck! looking forward to seeing the final product regardless what you get!
I actually like the GTS too. I am not a big fan of doing something super flashy, just something that looks good. the last two wouldn't be high on my list. But either the first Axis Super Hiro and the GTS would look good.
Do you have tints done?
Well it would say AWD on the trunk. You'd also have a very large bump in the floor-pan on the driver's side. You could also look for front axle shafts from the hub to the front differential. You'd also be able to see if you have a front differential and/or transfer case under the car.
Alternatively you could look at your data tag on the driver's door jam, there will be a chassis code listed there. For the IS250, GSE20 is RWD, GSE25 is AWD. (Others include GSE21 for IS350 RWD, GSE26 for IS350 AWD, GSE22 for IS300 RWD, ALE20 for IS220d, USE20 for IS F).
There are other ways to tell too, but I think the first couple I listed would probably be easiest
Jeff
Jeff
combfilter
Southwest
09-30-07 01:02 AM
