(That is to say they have the same bolt pattern, hub size, and thread size -- M12 x 1.5; the studs themselves are a slightly different length between the IS and Camry, just barely).
The IS one is a mm or two longer than the Camry, but that doesn't mean much since you also need to know the thickness of the hub and rotor hat area to know actually how much sticks out of the assembly. They may end up being the same.
Jeff
Yeah, that makes a lot of sense. I'll give it a shot and i'll make sure i get enough turns when i tighten it.
