OEM HID or after market HID..
Old 10-21-11, 11:02 PM
2genIS
2genIS's Avatar
Question OEM HID or after market HID..
hi,
I just bought 06 is 350 w/ out HID.. Which is better choice in a long rung and cheaper of bulb is burn or ballest is bad. Should I get OEM ballest and bulb or should I get after market HID KIt?
thanks
Old 10-21-11, 11:33 PM
KillaIS250
KillaIS250's Avatar
Honestly, just get the aftermarket HID kit. OEM ballasts are not cheap. Just get a quality HID kit and you should be good. There are plenty out there, just don't buy a cheap china-made kit from eBay and expect the ballasts to last
Check out the vendors section here, there are some vendors offering good deals on quality kits too
Old 10-22-11, 01:09 AM
Jetfire
Royale with cheese
Jetfire's Avatar
Cheaper is definitely the aftermarket kit. If you want the best output, Look into a retrofit.
Old 10-22-11, 07:23 AM
RDIS250AWD
RDIS250AWD's Avatar
I would buy an oem ballast and aftermarket bulbs if you want a diff color temp. Its costly for the oem ballast but from experience most aftermarket ballasts don't last long, and even worst they tend to make your headlights flicker.
Old 10-22-11, 09:28 AM
crookedIS2
crookedIS2's Avatar
I have had my xenon depot kit for over 2 years now and never had any problems with it.
Old 10-22-11, 01:13 PM
BAUSauto
Former Sponsor
BAUSauto's Avatar
We sell JDM high quality HIDs and exterior interior LEDs!! Let me know if you guys need anything!!
Old 10-22-11, 02:01 PM
allst4r
allst4r's Avatar
i have oem for 4 years no problem.. here i want to upgrade my fogs to hid but scared of poor build quality on the aftermarket kits.
Old 10-27-11, 08:20 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
OEM is not always the best in aftermarket applications. OE ballasts are designed specifically for an OE application where the ballasts are often mounted in areas that are protected from the elements. In aftermarket HID applications the ballasts are often exposed so they need to be completely water tight. XenonDepot HID ballasts are epoxy sealed and water tight to prevent any damage from moisture or water.
Hope this helps,
Steve
Old 10-27-11, 10:05 AM
Sango
Sango's Avatar
Which year/model car you have?
If you want a quality ballast and willing to spend the money, you can go with Philips. Nigel-JDMParts (forum vender) is selling them. I currently have one on the way and he will ship it to me once it arrives. I ordered the H11 version since my fog lights for the 11 car uses this type.
http://www.nigel-jdmparts.com/Philip...nverstaion-Kit
Old 10-27-11, 10:40 AM
brociouz
brociouz's Avatar
If you have a non-HID car, I would just go custom aftermarket. Do it right and retro in some projectors, add some LED accents, etc. It'll be cheaper than OEM, and if done right, better and different. My $0.02.
whiteghost
RX - 3rd Gen (2010-2015)
03-14-16 08:37 AM
BelaRuski
07-17-10 10:22 AM
BlackGhost
04-17-08 01:57 PM
DangGS3
Lighting
12
02-20-07 06:05 PM
BLK13X
Lighting
04-16-03 11:37 AM
Quick Reply: OEM HID or after market HID..
