OEM CF hood wrap to cover unsightly etchings
So I think I've decided on my next mod...to cover the OEM hood with unsightly bird etchings with a "wet" 3M CF DI-NOC CA-421 wrap. But I've got a few questions, as I've only just decided on going this route last night :
1. Cost...materials and shipping only. Any pointers on whom I should purchase the wrap from?
2. Amount of material and excess, plus anything else needed to do the job right the first time.
3. DIY? Though I've tinted windows, head lamps/fog lamps...this is new to me. Do I dare DIY?
4. Longevity. How long does a good, quality 3M wrap really last? Car will be garaged, but out in the elements during the day time.
5. Care. How is the best way to maintain the best look AND feel on the wrap over time?
I've never been a fan of fake CF parts, but I'd rather do this than fork out $$$$ on new paint or a real CF hood at this time.
Thoughts/comments/suggestions?
BTW, ever wanted to see a FULL CF wrapped IS350?
Thanks!
Thanks!
I actually saw that CF wrapped IS350 around UC Riverside when i went there. I believe he was a student there too lol. It actually looked pretty good in person. But its too much CF for me
1. Cost of CF will vary with what size you need. Just measure the hoods dimensions and add for excess to see how much you need minimum. Some places you can check for pricing...
http://www.metrorestyling.com/3M-DI-...p/dinoc421.htm
http://store.carbonfibergear.com/3m-...on-fiber-vinyl
2. From what i gathered (was going to wrap my roof myself) it's best to have 6-12" of excess material on each side. You'll need patience, a heat gun, and a soft squeegee tool to help you flatten it out as you go. X-Acto or other fine blade to trim to fit. You may also want to get some 3M Primer 94 to help the vinyl mold to the curves easier.
3. Yes DIY. It's honestly not much more than thoroughly cleaning/prepping the surface the vinyl goes on, laying down the vinyl, and then having lots of patience to work from end to another using the heat gun and the soft squeegee tool. to make sure you take out any air bubbles or creases.
4. It's supposed to last about 4 years outdoors. Most sites will say something in the range of 3-5 years for outdoor longevity. It lasts over 10 years indoors though. It also depends on how you clean the surface and take care of it. If your taking your car through automated car washes all the time, i'm sure it wont last as long lol.
5. Besides just washing it with regular car soap and a soft microfiber, i've only seen this recommend for its care.
http://www.303products.com/shop303/i...yl-cleaner.cfm
Hope this helps. Post pics when your done!
Your first problem will be finding "wet" carbon firber vinyl. I have gone through three different types of vinyl and none of them have even gotten close to the wet, glossy look of real carbon fiber.
To cover your whole hood will cost you quite a bit, probably close to $300. I have seen numerous real, carbon fiber hoods in our classify go for $400. IMO I would spend the extra $100 to get the "wet" look.
Otherwise, DIY on the wrapping is very easy. I have no experience in wrapping anything (literally, I cant even wrap a christmas present) but after experimenting on one window pillar, i was able to perfectly wrapped the rest of my pillars and a rear diffuser. Its very easy. I also would suggest getting a heatgun.
Yeah I'm not sure it's gonna be possible to find a "wet" CF vinyl, because than a bunch more people would have preferred that do that "dry" 3M. Just whatever vinyl sheet you buy, and you need to be careful because they dont produce many with a width of over 48" for the 2GIS OEM hood. Been trying to do the same thing myself...
After my measurements I believe 5ft x 6ft will be perfect.
I found this on ebay...and after some research on this particular 3M CF wrap it looks promising, and for a better price : http://www.ebay.com/itm/3M-1080-Blac...#ht_3107wt_966
See if seller is willing to send you a sample size. I don't see any in his listings, but many sellers on eBay usually will send a sample size. I got a few from eBay sellers when i wanted to buy some CF wrap.
Might also want to check out...
http://vcarbonfiber.com/
