Newbie looking for advice (Buying an IS)
Correct me if I'm wrong but I also didn't see the cam gear TSIB performed. This also affects pretty much every 2IS and costs $1600 out of warranty. It manifests as a grinding/cranking noise on startup (search CL for engine cranking startup for the thread on it).
I did see water pump replaced which is common for cars getting close to 100k.
I also think I saw all the relevant recalls performed.
I am very concerned about the cam gear and dash TSIBs though.
From what I read in those threads you posted those are technically both just nuisance issues? I know obviously the dash rattle is one of them, but I recall reading the cam gear issue was only produced the noise upon startup and then disappeared and that it had no real impact on the car?
Either way I'd prefer they were done and I'll have to talk to the dealer about both of those. Luckily it seems all of the service was performed at one dealer so perhaps I'd be able to give them a call with the VIN and talk to them about it. If they are anything like the local dealer I used they should hopefully remember the car and owner.
It does it on startup and occasionally on engine shut down. No issue, but they did say it can be a performance/reliability issue so they would fix if if the car has this symptom. It does not hurt the car because the cam gear has a bit too much free play so depending on the oil pressure, it would do that randomly. With the updated cam gears, they are tighter in tolerance which prevents this from occurring.
The $1000 cost is the time to take the dash apart and put it back together... it's not hard to do yourself over a weekend, just time consuming.
That's not too bad. I do enjoy projects, so it doesn't sound too bad. Is there a write-up someone did of it? Also, is the cam issue one that would be extremely noticeable when I turned on the car or would I need to be standing outside while someone else turned it on?
Keep in mind it doesn't happen on every startup. In some cases itll happen almost every time, other cases it will happen 1 out of 10 starts.
As luck would have it a very similar car showed up for sale at a local dealership very close to me; however, it was at the Lexus dealership getting service done when I wanted to go look at so I'm supposed to be receiving a call back when they get it back in a couple days. I was wondering if anyone could run the Lexus service history since it still isn't working for me. The VIN is: JTHBE262662003995 and the link to the car is:
http://www.mississippimahindra.com/n...-MS-39402.aspx
The price seems just a little higher than I think I could get the car for so hopefully they are willing to negotiate...especially once I find out how in depth the service they are completing now is. Also, is there anyway to tell what options the car has by checking the VIN? I'm wanting to see if this car has the Luxury Package like the other one did. Is the heated/cooled seats only available on that package so could I just look for that?
Thanks again
Thanks again
^ Looks good!
According to this....
https://www.clublexus.com/forums/is-...-packages.html
....Looks like this one is only the Premium package. With the heated seats, wood trim and perforated leather. Luxury package has memory seats, this one doesn't. This one wont come with the rear sunshade or HIDs either, which i believe are standard on the Luxury package. So this car is basically less equipped for a higher price. The only things better than the other one i guess are lower mileage and closer to you lol. Hopefully they are doing the 60k service on it at least (if it wasn't already) if they say they are servicing it at the moment.
I'll try and get the service report for you when i'm home again, unless someone gets to it before me lol That's if you even want it anymore knowing its just the premium package!
Well darn...rear sunshade isn't that big of a deal, memory seats would be nice, but again not a must. What bothers me the most is that it doesn't have HIDs and my guess is also the auto-adjusting lights? (forgot what they are called, the lights that adjust to corners). However, knowing that I could always upgrade to HIDs and live without the adjusting or doing it all the way (for of course a hefty price) if I could get this car for a decent price it seems like it'd be decent. I thought there was a difference between just the heated option and the heated/cooled. On the website they have pictures of the center console and you can clearly see the heating and cooling options. There aren't any Lexus employees that could pull the original window sticker are there?
There are a few members that work at Lexus dealerships that can probably pull the sticker, i'm not sure who they are tho so it just depends on if they see this thread lol.
Thanks again
Thanks again
That is premium package with Nav and 18" wheels for sure. Premium is woodgrain and the heated/cooled seats.
No luxury package, and no HIDs (for 2007 and newer models it COULD optionally have HIDs regardless of having the sport or luxury package- but for 2006 models HIDs only came with sport or lux...which means no memory seats=no HIDs for 2006 models)
Memory seats and trim type are the key features for spotting Luxury or Sport or premium package- Memory+woodgrain=Lux, Memory w/out woodgrain=Sport, No Memory WITH woodgrain is premium.
