Need some help i have couple lights on my dash
#35
I would try to find out which end (ends) on the car was damaged and look for unplugged/hacked wiring harness's... With that much going on, it might be a major plug or a harness that was crushed... or a major ground point not connected or destroyed
As a starting point the EPS unit (power steering) is under the battery... I hate random electircal issues, but if you can find out what was done to the car, it will give you a good starting point..
#36
i took it to the dealership and they told me only that the power steering rack needs to be changed and that one of the abs sensors was cut off on the driver front side. i found the power steering rack with 1yr warranty for 340 shipped to my door, and the abs wire was 60 some bucks. not too bad. I got another problem though the dash where you change the temp. The buttons auto, off, fan speed , mode, dual, ac, circulation, and etc. the buttons are dead no response at all. I'm not sure if its the fuse and where would this fuse is located, i searched and checked everything i thought it could have been and they all looked good to me . any ideas what could be wrong, let me know.. thanks a lot guys ( the buttons I'm talking about i have a picture on first page, first picture)
#37
If you're looking for the fuses for the radio, it is located under the glove box and is covered by a small white lid. You would have to be likely be on your back looking up to be able to see the fuse box.
