Varrstoen Wheels
Old 03-19-12, 04:13 PM
  #61
danhtran
danhtran's Avatar
Originally Posted by tp350
He is lowered more which in turn creats more negative camber pushing the top of the wheel inward. He may also have adjustable camber arms (poss. Figs lower control arm or megan for rear, sbc ball joint for front). He is also stretching much more than I am. I am currently running 225/40/18 and 255/40/18.
thats explain a lot
well i dont wanna do all that roll fender or camber kit and ......
i just want mine to stick out like your, so i think imma get F19x9.5 +22 and R19x10.5 +22
hopeful since im on H&R springs so i dont have to roll fender and all that...
btw where did u get them?
Originally Posted by juvi22003
Danhtran - If u goin with the +22 and +25 offset i recommend 225 or 235 35 and in the rear 245 or 255 30
thanks
Old 03-19-12, 04:20 PM
  #62
danhtran
danhtran's Avatar
Dont have varrstoen setup but i know a few things about there wheels. You can run a 19x9.5+22 and 19x11+25 with stretch tires and they will stick out.
here come the dump question
they dont make tires that big or something? why do you need to stretch tires?
  #63
laobo979
laobo979's Avatar
Your still gonna have to roll on that setup+22. You need to stretch to clear your tires from rubbing the fenders/ fender sitting on your tires.
Old 03-19-12, 04:48 PM
  #64
kingz415
kingz415's Avatar
interested in this setup as well. anyone have a pic of this setup with h&r springs?
Old 03-19-12, 07:28 PM
  #65
MoarLow
MoarLow's Avatar
those pics in original post looks like both the tire and wheel are sticking past the fender and looks like there's wheel gap...doesn't look good at all.
Old 03-19-12, 09:24 PM
  #66
danhtran
danhtran's Avatar
any1 else has this rims??
Old 03-19-12, 10:03 PM
  #67
MashinA
MashinA's Avatar
Pretty much sums it up. Fenders are rolled a lot, running 215/35f and 235/35r, megan camber arms spc ball joints, camber is at -3 f and -4r and still rubbing
Old 03-19-12, 10:37 PM
  #68
is150
is150's Avatar
Yes they make tires big enough. But to be able to run such aggressive widths and offsets you have to undersize your tires (stretch) them to get them clear the fenders. Even with stretched tires youll most likely are still going to have to roll your fenders at a minimum.
Old 03-20-12, 01:06 AM
  #69
LamTheSham
LamTheSham's Avatar
I'm running 19x9.5 +19 (3mm spacer to clear stock IS350 caliper) and 19x10.5 +22 on 225/35-19 and 245/35-19.
Rolled and pulled all around - only rub on big dips. LOTS of fender work. Gotta cut out a ton, either ziptie or move the fender tab, and I need to shave the rear fenders a bit more Slammed - one finger gap between rim and fender in the rear, two finger gap between rim and fender in the front. Camber kit in the rear would definitely help, but I didn't need it. I've got almost a full turning radius, aside from a little scrubbing on the fender. I've never really been a huge fan of the massive amount of poke, but I definitely like aggressive fitment. Natural camber makes it so that everything sits perfectly flush with it. Hope it helps!
Old 03-20-12, 08:05 AM
  #70
TrancEpimp
TrancEpimp's Avatar
basically you gotta pay to play! .. lower offset's mean more money $$$
Old 03-20-12, 08:26 AM
  #71
juvi22003
juvi22003's Avatar
Thanks for replying.....
Old 03-20-12, 10:02 AM
  #72
projectdna
projectdna's Avatar
quoted for truth.
unfortunately, replica wheels (like varrstoens) make it more affordable for people to play the fitment game.
Old 03-20-12, 10:08 AM
  #73
heyarms
heyarms's Avatar
Sometimes Discount Tire wont do stretched tires because they say "the tires dont fit the wheel".
I know you arent a fan of EVS man, but if you're buying brand new wheels, I'd suggest using them for their touchless tire mounting machine so your rims stay as flawless as possible. The old school tire mounters use the metal grips on the side of the rim and they pry the tire on with a metal pry bar (at small shops at least).
I'm not an EVS motors fan either, but until i find another place close with touchless tire mounting, i will still have to go to them. They are clearly able to and willing to run stretched tires for you too.
Old 03-20-12, 04:53 PM
  #74
danhtran
danhtran's Avatar
i learned something. thanks
truth
haha good advice
i guess i gotta go back to them soon tho
Old 03-20-12, 04:59 PM
  #75
danhtran
danhtran's Avatar
actually help a lot
thanks
Quick Reply: Varrstoen Wheels
