LED HELP pls ! :'(
Hi everyone,
So I changed interior dome light, front map light, vanity light, puddle light, and courtesy light all to blue LED. Everything was working fine, until when I Was changing out the last courtesy light, after I installed it all the LED would not turn on.... what happened.. some say I might have blew the fuse.. ?
Please help! :'(((
Please help! :'(((
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Most likely a fuse was blown....like brociouz said.
I believe the fuses are under the passenger and driver side kick panels. These can be found in your owner's manual. If not, then a brief listing of the fuses are on the back of the fuse cover.
After you check it and if it is blown, check the last bulb you put in. Make sure it's not defective. Something caused your fuse to blow.
Good luck
Good luck
Dang man, looks like you are going to have to sell your car now! CRAP!
J/k....The fuses are on both the driver and passenger side floorboard. Just crawl down on the floor and look up, you will see a white door with fuses behind them. They are "mini" fuses like the picture below. You can buy more at AutoZone, O'Reilly, or any place similar.
![](http://dackpatrick.com/is350/interior.jpg)
![](http://www.photo-top.com.tw/images/miniFUSE.jpg)
Thanks for your inputs.
So this has nothing to do with I have too many LED / LEDs that are too bright? Lexus said these LED are too bright and can get really hot and will start burning stuff.
Currently I've installed:
1. Front map
2. Dome
3. Puddle
4. Trunk
5. Courtesy
After I get the fuse replaced, would this setup cause more problems in future?
1. Front map
2. Dome
3. Puddle
4. Trunk
5. Courtesy
You blew a fuse. You were probably installing the LED when the circuit was hot. Replace the fuse and all will be well.
LEDs draw less power than standard bulbs, so it's not an issue of electrical capacity. I have everything changed out to high power LEDs in my car, no problems.
