Genesis coupe track wheels question
#31
You should be ok in the rear with a 255 tire. Wheel is a 19x8.5 +35. For comparison, my G37 wheels are 19x9 +30 (with the 15mm spacer installed) and I'm running a 255/35/19. I am not rubbing at all. I have trimmed a little off of my fender lip because I was rubbing with a 20 mm spacer, but I wouldn't have had to trim if I had initially had the 15mm spacer. So, with your 5mm less offset and the fact that you are running a 8.5" rim, you will be fine.
#32
08 rwd 15 mm Spacers up front and 225/35/19 on Tein springs. Any ideas why it is rubbing now? Just installed wheels yesterday. Everything else was already on there with the factory wheels
#33
With that wheel (which is a +35) and your 15mm spacer you now have a +20. You running S-techs or H-Techs? Rubbing on plastic only? You may have to tuck the plastic under the tab to keep it from rubbing or roll the fender.
#34
#37
@ Marexus, I dont know the size of the caliper but on my 250, there is alot of room. when i get home, ill measure it for you.
#39
the other guys pointed you in the right direction and i can confirm, it is the liner. Ive been lazy and still rub. its the center of the liner on the bottom. there should be a part protruding, just heat and push it in. If you take the spacer off it WILL go away.
Although CCJ22 has the wheels and he says they wont fit
#40
Anyone know what lug nut type the Genesis wheels use? I'm thinking a tapered seat of some sort by the looks of the lug flange on the wheels. If this is the case then some aftermarket lugs would be in order no? I don't want to get flamed for asking for suggestions but my eyes are bleeding from general searches this week. Please
#41
Anyone know what lug nut type the Genesis wheels use? I'm thinking a tapered seat of some sort by the looks of the lug flange on the wheels. If this is the case then some aftermarket lugs would be in order no? I don't want to get flamed for asking for suggestions but my eyes are bleeding from general searches this week. Please![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
#42
I have these wheels. You'll most likely want hub rings too. (just google what a hub ring is)
That's a 60degree acorn style lug.
I should know I have an IS250, with black powdercoated genesis track 19" wheels, tuner style lugs and the proper hub rings size.
I am not lowered but have dealt with lowered cars before. If you have rubbing it's a simple fix of either removing the liner or heating up the area it rubs at and deform it upwards/inward
#43
#45
So I took the spacer off of the front and they are still rubbing. Looks like I need to find out where it is rubbing exactly. Does anyone have pictures of where the wheels rub against fender liner? Would be really appreciated
