Genesis coupe track wheels question
Old 12-02-11, 04:19 PM
  #46
viprtwo
viprtwo's Avatar
its most likely rubbing on the outter area of the fender if u have a 5mm spacer up front.
i'm running these with a 225-40-19 tire, and a 5mm spacer on the front to clear the caliper. It still scraps over bigger bumps. it's rubbing the outside corner of the tire against the top of the fender where they these two areas meet.
I've already pushed in the plastic and done as much to the fender liner as possible. The only way not to rub is to raise the car or get 225-35-19 or 215-40-19 tires
I have the rears on 255-35-19 and lowered on eibach pro-kit. the natural camber saves the tire from scraping
Old 01-07-12, 02:38 PM
  #47
tBayBoi20
tBayBoi20's Avatar
Originally Posted by Nuckingfut
Im in the process of doing this exact mod. I just received my wheel set earlier this week and have just found a center cap set from my local hub cap shop that after some dremel action fits nicely.
Looks like I am going to try out some V12's in 225/35/19 & 255/35/19. I'm a little worried about the 255 fitting on this rim and in the wheel well without issues. I may get away with it at stock height but if I drop 1+" or so it may be a different story.
Attachment 226599
Attachment 226600
That looks clean man!
Old 01-07-12, 07:10 PM
  #48
sleeper24
sleeper24's Avatar
Originally Posted by birador
gotcha there,every single person has a different taste,as long as it look good in your eye and think what is best for you,get it!!!!!be proud on your decision and if your not satisfied-replaced it!!!
+1 I couldn't have said it any better. When you buy something others like and you don't like, you will always end up regretting it and replacing it. Honestly, I love the way the rims look on the 2IS. Makes the car looks like a sleeper, especially on the IS350.
Old 01-08-12, 01:26 AM
  #49
LILDANTE79
LILDANTE79's Avatar
I have them. I used a 25mm up front and a 20 n thee rear 225/35 and 255/35 u don't need spacers to clear bbk it was fine with my old rotoras
Old 01-08-12, 09:58 AM
  #50
VIS250P
VIS250P's Avatar
HAWT!!! Thinking abut getting this for daily rims
Old 04-19-13, 09:35 AM
  #51
JoeSupra
JoeSupra's Avatar
What which tire pressure sensors you guys using?
andthen
09-22-17 01:29 PM
crenfro
Suspension and Brakes
25
10-18-14 10:18 AM
Jussjoshin
Pacific
13
06-21-12 12:23 AM
Vroomin350
08-08-11 11:54 AM
LeXaNoMicS
02-18-09 10:57 AM
Quick Reply: Genesis coupe track wheels question
