F-Sport Badge
#33
You can get them from Sewell. Make sure you log in with your clublexus log in for a discount.
http://is.sewellparts.com/accessorie...S350-2011.html
Are the horizontal f sport logos OEM? maybe JDM...
#36
How do you know where exactly to place the badge on the front fender? Is there a template or do you just estimate the location?
Also, does the badge adhesive last or will eventually the badge come loose?
#38
#41
Jeff
#43
I just worry that 2-sided tape will not hold over the long term.
#44
Yes your spoiler would have had holes drilled, however there are instructions and a template for where the holes would go, and there are studs/nuts that are used to hold the spoiler on.
The fender badge holes are for locating only, they do not hold the emblems on in any way. They are held on with 2-sided tape from the factory just like every other badge/emblem on the car. They're not going anywhere.
Jeff
Jeff
#45
Jeff
Jeff
So in Joe's photos of the badge, I'm guessing the blue backing covers the tape? Also, how do you remove the pins? Do you snap them and then sand them down?
