Amp wire diagram is this it?
When I did my subwoofer wiring, this is the diagram I referred to. Subwoofer wires are brown(+) green(-), pink(+) blue(-). They're found on the 3rd connector from the back of the car (for my 06 non-ML non-navi). I only hooked up the brown and green.
If you choose to hook up the front woofers also, they're white(+) red(-), and brown(+) pink(-). Those set of wires are found on the 1st connector from the back of the car.
My memory is a bit vague, so I'm not 100% certain on the locations, but from what I remember, that diagram was accurate.
CaliFRESH89 (10-27-23)
Only 1 subwoofer... on the back deck, but 2 woofers in the front doors... The one on the front dashboard is not a woofer.. on a ML system it is a front center channel for surround sound... I'm not sure if it is used at all on a non-ML system but I'm sure someone on here can tell you...
stiles17
09-01-14 02:27 AM
