Fitment/Stance Question, Need Opinions (pics inside)
Old 11-01-11, 11:41 AM
MashinA
MashinA's Avatar
Default Fitment/Stance Question, Need Opinions (pics inside)
Aite so I got these temp wheels on and I wanted to try the poke look rather than tucking. The way it sits now the front is fine but the back rubs on dips and turns. I want the poke but I also wanna stay low so the debate is should I raise the car a lil like half an inch in the back to get the clearance or stay as low and camber the back more to clear the fender givin me more of a tuck/flush look. Will it look weird if the back is tucking while the front is poking... what do youthink
Old 11-01-11, 11:55 AM
sick
sick's Avatar
I think if you raise it just a tad like 1/4 inch it would look ok. It looks good now just a little uneven. Also, what offset is the front if you don't mind me asking? I understand if it a secret, lol. Car looks great btw!
Old 11-01-11, 12:05 PM
MashinA
MashinA's Avatar
From the ground to the fender right now its the same distance, however the body of the car is just slanted forward so it looks like the back is higher. Offset is +12
Old 11-01-11, 12:11 PM
JYOO
JYOO's Avatar
Tires dont fit.
Old 11-01-11, 12:24 PM
MashinA
MashinA's Avatar
It's not the tires that rub its the wheel
Old 11-01-11, 12:26 PM
Damaster32
Damaster32's Avatar
whats the specs on the wheels?
Old 11-01-11, 12:36 PM
UtoyZ
UtoyZ's Avatar
are your rear quarter panels completely shaved? i'm pretty sure that's where you rub. i agree with raising the rears about .25" and perhaps a 5mm spacers.
Old 11-01-11, 12:39 PM
MashinA
MashinA's Avatar
Wheels are 9.5 10.5 +12
How will the spacer help?
Old 11-01-11, 12:55 PM
sick
sick's Avatar
IMO, I think there should an be equal amount of poke or more poke in the back. It kinda looks like you have the wider wheels on the front in the first pic. What happened to your works?
Old 11-01-11, 01:04 PM
UtoyZ
UtoyZ's Avatar
Will it look weird if the back is tucking while the front is poking... what do you think
spacers in the rear will give you the even front and rear poke look
Old 11-01-11, 01:09 PM
Sffd103
Fire Slayer
Sffd103's Avatar
You've run into the issue I dislike about the flush/poke movement. I like to ride LOW...as do you! Only problem is kissing your fenders/quarters. I'd say raise the back a bit if you want to keep this look going. Wheels are SICk BTW!
Old 11-01-11, 01:43 PM
edgeucated
edgeucated's Avatar
Raise the rear a tiny bit. It looks nice
Old 11-01-11, 01:50 PM
MashinA
MashinA's Avatar
They'll be up for sale soon
the thing is I can't afford anymorepoke in the back unless I jack up the car more... I'm at like -5 camber which I can adjust for more poke but like I said then I have to raise it more
I think I'm leaning towards this for now
Old 11-01-11, 02:45 PM
birador
birador's Avatar
yeah +1 on raising the rear a little bit,that's the best solution so far or else get rid of your wheels and change it
Old 11-01-11, 04:16 PM
Alias
Alias's Avatar
i'd go with raising up the rear a bit, because it looks pretty solid right now. but i agree with sick, it does look a little off in the first pic cuz there's more poke in the front right now... but thats just me.
Quick Reply: Fitment/Stance Question, Need Opinions (pics inside)
