Last edit by: IB Advertising
Browse all: Steering and Suspension
- Are Spacers Safe?
Important information to help you understand your Lexus
Almost DIED tonight thanks Ichiba V2 Spacers
#32
Wow I was also looking into a set of Ichiba spacers. Are there any other brands that seem to have better quality? did you get in contact with Ichiba? I'm eager to see what kind of response they have.
#33
your experience is a wake up call to all members using spacers not only the brand that mentioned but all to check always their tires ,me myself has a spacer also but every single day i check it because it's not worth to be sorry than to have a flush ride-sorry to hear that and thank god that nothing happen to you plus the factor that it happens at a unfamiliar territory of yours
#34
At this moment I'm not sure if I want to even have the added stress of hassling Ichiba about this issue. I will never uses V2 spaces or any type of spaces again, even if they offer to replace the set free of charge. I'm just glad I didn't really mess up my car or worse be murdered by that homeless guy on the bike.
But I will keep you guys posted if I do bring this to Ichiba's attention.
#35
#39
This looks like a stud issue, and I've seen broken studs on stock hubs too. The main issue I have with bolt-on spacers is the extra stress from pulling the aluminum in both directions so close together, resulting in cracking.
This issue is not even a spacer issue, this is a stud issue. Without knowing the quality of the Ichiba studs, it's hard to say for sure, but whenever I've seen this happen, on stock studs or whatever, it was due to over-torquing the studs at one point. (Whether it broke at that time or later).
You may have reasons to hate bolt-on spacers, whether it be the extra stress on the bearings, not being able to easily check the torque of the inner nuts, stresses on the spacer itself causing cracking, etc., however this issue seems to be either an installation problem (over-torquing), or a quality issue (weak studs). Either way, all I'm saying is that there are many valid reasons to hate spacers, but what happened here is a stud issue, that can (and does) happen to even stock studs. Using aftermarket longer studs with non-bolt on spacers, or really anything as far as studs go could result in a similar situation.
Broken studs are no laughing matter, but why they happen is an issue not related to having spacers, just what quality of stud they used, and if they were abused or not. It could happen with or without wheel spacers.
Jeff
Jeff
sede7 (12-13-20)
#41
Jeff
Jeff
#44
Your spacer doesn't look like its hub centric. You're putting all the weight on the studs instead of the hub. You should look for a spacer that is hub centric to the hub and to the wheels.
