Old 12-12-14, 04:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Almost DIED tonight thanks Ichiba V2 Spacers
Old 07-30-15, 07:36 PM
  #121
masboy
masboy's Avatar
I ran ichiba II 25mm spacers on my 2gs for 40k miles or so. Not a single problem
Im running ichiba II 15mm spacers on my low 3GS as right now for 10k miles so far and not a problem so far.
Its gonna b User Error ID 10 T that got u into issue with spacer. U gotta know how to install it properly. SMH
Old 08-01-15, 10:20 AM
  #122
prada_g
prada_g's Avatar
Another spacer supporter here .
I had hubcentric generic no name eBay 20mm spacers on my daily driven IS for 4 months, zero issues. Just took them off recently so I could fit some wider tires & neither show any cracks/signs of damage.
Old 08-01-15, 12:27 PM
  #123
Nespo2330
Nespo2330's Avatar
ugh either way that's scary as hell
Old 08-01-15, 10:16 PM
  #124
smokyis350
smokyis350's Avatar
You are brave with some eBay brand. People are having issues with reputable brands and you are rolling with some no name brand from China.
Old 08-01-15, 11:20 PM
  #125
700bones
700bones's Avatar
Yeah ok, thousands of people use these with no problem, and YOU just happen to have a problem, so of course it's the spacers' fault!
Come on, use class 8 studs and torque it down to spec, not just get china type bolts and crank it down to whatever with a lug wrench.
Old 08-02-15, 11:16 AM
  #126
smokyis350
smokyis350's Avatar
Where did I even say I own spacers?
Old 08-02-15, 06:01 PM
  #127
cruzinZ
cruzinZ's Avatar
Buy wheels that have the correct offset and you won't have to use wheel spacers. Any time you introduce a piece that has the opportunity for failure you are taking a risk. If the wheel you like doesn't come in the correct offset its not the right wheel for your car.
Old 08-02-15, 07:39 PM
  #128
jennie
jennie's Avatar
Everything is at risk for failure, even stock wheels and studs. Not buying a set of wheels just because you're afraid to run spacers... More wheels options for everyone else I guess.
JDW379
01-30-14 04:53 PM
stockySC4
Wheels and Tires Classifieds
04-09-10 10:47 PM
pizdets17
10-26-09 09:21 PM
Infamous 1
05-01-09 09:31 AM
Quick Reply: Almost DIED tonight thanks Ichiba V2 Spacers
