help, car shaking
#31
So a few things here:
1) The OP is having 2 issues, the one he's described in the first post AND the cam gear TSIB/engine cranking noise. They are unrelated. The first issue is throwing a CEL that's broken down in post 10.
2) The OP is NOT suffering from the carbon build-up issue, because he has a 350 and the carbon build-up issue only affects 250s. However, the symptoms are very similar.
3) As stated above, the Check VSC light is only on because the CEL is on (VSC light comes on any time there's a CEL on the 2IS).
4) Recalls are free no matter when, TSIBs are only free if they're covered by a warranty you're still under. If it's a powertrain TSIB (like the cam gear issue the OP is suffering from), then it will be covered for 6 years/70k miles.
5) As far as worrying about maintenance bills, don't worry about recalls because they're free. Outside the few TSIBs that affect many 2IS (carbon build up, cam gear, both of which covered by powertrain), there are very few common issues on the 2IS, and those that it does have are usually rattle-related. It's a very reliable car. However, that's why I'm so intrigued by this issue - I haven't heard of a problem causing symptoms like this on a 350.
6) Gas in a loaner car from the dealer is not free. If you don't fill it back up to the level it was at when you picked it up, they'll charge you.
#32
Thanks for all of the clarifications calvin.
I am really starting to (and hoping) believe that it is my spark plugs and wires. I have never changed them, they call for 60k. My car is only half that, but it is almost 6 years old. When did you guys do yours?
#34
I have an 07 IS350 and I changed my plugs right at 60k miles a few months ago. I noticed absolutely no difference whatsoever in gas mileage or performance, which is what you'd expect given that the spark plugs can last much longer than the recommended 60k. A lot of people will claim on here they noticed a big difference, but I think that's the placebo effect hard at work; after someone spends 5 hours or $500 getting spark plugs changed, I can see how they'd hope to experience a big difference.
Definitely keep us posted, I'm very curious to know what the issue is.
#35
Personally, being the DIY'er, I would start by replacing the spark plugs. Simple and straight forward. If that CEL came back I would swap coil packs around to see if that "bad" pack switched to a different cylinder. If so, simple fix...replace the pack. If no change, I would lean towards a O2 sensor...and that's at the point it starts to get pricey.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#36
I figured id wait until they diagnose it since they are doing it for free. The service guy said that if it is serious, there is a good chance lexus would help me out. since the car had so many recalls, was always maintained at the dealer, has the upgraded 100k powertrain, and only 26k
#37
Update, I took my car in today. They told me it was the spark plugs, so they went ahead and replaced them for like 280$ I would do them myself but I think I would rather have it on them if another problem arises. I also made a complaint with Lexus for a reimbursement. I understand that they are wear and tear related, but I have not hit 6 years or 60k. What do you guys think, will they reimburse?
#38
#39
I don't hit the 6 years until July. So I was thinking that I have some kind of argument. Either way, if it is fixed for 280$ it's not the end of the world. Also, since I have the extended powertrain to 100k and every single maintenance item has been done and done at the dealership.
randomwalk
09-07-11 08:09 PM
