why do you lower a car?
#33
There's two issues here-
One, there is such a thing as too low. Lobuxracer has discussed this before, where the roll center of the car actually ends up below the road surface- then it handles worse. I've yet to see any evidence that anyone knows the "ideal" height for handling on a 2IS... so for all we know the stock sport suspension is already there. It'll take a good driver with good coilovers and a fair amount of track testing to really answer that question.
Two, most lowering springs are progressive rate springs, which is a compromise that's not only not great at anything and is less predictable on a track than linear springs, it's also impossible to match a shock to the full range of the spring.
ok, you're wrong.
If you want to stop shorter you need better tires, not a suspension upgrade.... (better brakes won't help here either... the tires are what stops the car)
many folks think so... me I hate scraping the front lip on low curbs or the whole car on speed bumps or driveways... a lesson my wife learned too when she lowered her supra against my advice, and 6 months later swapped it back.
#35
minimizing the gap b/w the fender arch and the tire gives the car a better stance which in turn is more visually apprealing but that of course depends on the kind of car being lowered and how much its being lowered. too low doesnt look good. its gotta be lowered just enough...
#39
here's my contribution:
Lowering a vehicle can sharpen the looks and increase performance dramatically. But what does it really do and why does it help?
Imagine a car as a giant 3000lb weight suspended above the wheels. When you turn, that weight is shifted opposite of the direction by gravity trying to compensate for the force. This is what’s known as body roll. This is what spills your coffee. This is due to a high center of gravity in combination with saggy springs. When you install lowering springs, you are reducing the center of gravity therefore creating less resistance on the chassis through the turns. This will result in quicker steering response and crisper road feel. The look of lowering car or truck is also unmatched. Closing that wheel gap that is present makes the entire look of the vehicle more aggressive. Be sure when choosing a ride height you measure all wheel clearances. The drop will be the amount from the bottom on the fender lip to the top of the tire. Make sure you have room! It is imperative! You may also want to look into spring rates. Different springs have different rates, which will affect the handling of the vehicle and the overall ride quality. Higher spring rates will yield a tighter suspension but a stiffer ride. Softer springs will still increase performance but will maintain a decent ride quality.
Choosing the proper spring takes a bit a time and research. Doing it right the first time will save you a headache in the long run. Remember when lowering a vehicle, it is generally recommended to add a camber correction kit. This will keep your alignment in spec and tread of your tires.
#40
Now thats how to say it in a nut shell..... LoL
#42
thank you everyone for your input. i really appreciate everyone's contribution. i need all the info i can get if i decide to go down this path.
birador, i'll be calling you directly if i need anymore information. *wink*
