new to forum; also need some advice about my brakes
Hello everyone, new to the forum here
I just traded in my 335is for an 08 IS350 w/ 26k miles on it. I'm loving the car so far. There is definitely a bit of trade off in the performance but I can live with that. I do get more luxury options in this car. I am looking forward to do some modding in the future. My 335 had a couple mods: JB4, FMIC, DCI, catless DP's, BOV's to name a few. I'll probably just do an intake/exhaust and maybe some interior LED's on this car and try to keep it as close to stock (yeah right).
Anyways I just picked the Lexus last Friday and I wanted to do a 30k service maintenence so I took it to a nearby Lexus dealer. The SA quoted me $500!!! That was a bit of a shock considering all they were doing was an oil change, air filter, and brake fluids. So I just did a pedal recall that was available on my car and had them check up on my front brakes that were making a horrible squeal when coming to a gentle stop.
I waited for about an hour and a half and the SA comes back and tells me they cannot replace the brakes under warranty. It turns out the previous owner changed the brake pads but used the wrong ones and were causing the the horrible noise. So I asked him how much they would charge me and he quoted me $900
. I said I would think about it and just left. He gave me the parts numbers to the parts I needed. Looks like I need new front rotors, brake pads, and a shim kit.
I just bought this car and I don't want to dump $1,000 in a brake job. I know there's a site for BMW's where you can get OEM parts for a cheaper price than at the dealership and was wondering if there is one for Lexus. Is http://is.sewellparts.com/index.php a good site to use for OEM Lexus parts? I also did a search and found that other ISx50's make this squeal in the brakes due to brake dust and there is TSIB(?) to fix it. Obviously I can't fix this through the dealership and I'm looking at buying the parts online. I searched up the part numbers on the invoice the SA gave me and it shows the parts for only the 2011-2012 IS350 models. Do I buy rotors, brakes pads, and shim kit for the 2012 models and put them on my 2008 model
Sorry for the long story but I would appreciate any advice. Thanks.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Here's a picture of the 335. Don't have any of the IS350 yet.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![](http://i1229.photobucket.com/albums/ee468/danny156b/6174091206_a07d0f9be1_b.jpg)
Thanks guys. Yeah I had a brand new 2011 335is. I'm going to go back as a full time student so I needed to drop the payments. Paid off the Lexus and just need to get maintanence in order. I don't regret making the switch though. It's definitely a great car. I also looked into the brake pads in the classified. thanks for pointing that out
about the squealing. i bought brand new rotors & pads and they still squealed at slow speeds. i eventually bought this anti squeal stuff at autozone that is in a spray can. i took my rotors off and sprayed both sides and added antisqueal lube to the pads and no more squeal ! ya! hope that helps
Next...don't ever, ever, ever ask for "the X miles service"
They'll jack the price up 2-3x and still only do the couple of items you ACTUALLY need, that if you just asked for THOSE ITEMS would be way cheaper.
At 30k you need:
brake fluid changed
oil changed.
Air/cabin filters changed (you can do these yourself in about 5 minutes tops)
Oil change and brake fluid change should be $150-175 total at most dealers.
You won't need anything other than oil changes again until 60k (which is the same as 30k plus spark plugs)... then nothing again but oil till 90k, which is same at 30k... then at 100k you change coolant.
Anything else is them trying to jack you for cash.
And to your other question on parts, yes, sewell is an excellent source- be sure to register with your club lexus screen name to see the special discounted pricing... the low-dust TSIB brake pads are like $100 or so... rears are like $65.
But you might just need some anti-squeal for a couple of bucks and a little time.. (or maybe just a rebed of the pads, which is free)
Unless there's deep scoring/grooving in the rotors, or significant vibration in the steering when you brake, you certainly don't need rotors at all.
Yeah I figured I would buy the 30k maintanence kit on the sewell site and do it myself. And as for the pads/rotors, the SA didn't say what was wrong. He just stated that the wrong type of pads were used. I checked the rotors and they were completely fine. No grooves at all. He also mentioned that the shim's were missing. Do you suggest I just buy new pads/shims and go with anti-squeal spray/lube?
https://www.clublexus.com/forums/sus...or-squeak.html
For parts, sewell is way to go but you can also try here at carson lexus/toyota/scion to compare price.
http://www.trademotion.com/partlocat...?siteid=214915
Good luck.
For squeal at light braking, print out the TSIB, L-SB-0015-09 from the following link and try at another dealer. When I walked in to my dealer with that TSIB, they performed the TSIB, replaced anti-squeal shim kit, and the problem went away. It was free under warranty.
The problem is he doesn't have OEM brakes on the car apparently.... so they're not going to give him a free fix of an OEM part when he doesn't have that part on the car.
to the OP- assuming you've got some pads throwing out a lot of dust in addition to the noise, yeah, I'd get the low-dust OEM pads and new shims if yours are missing and give that a shot. Be sure to bed em properly too.
Kurtz pretty much captured it all. NEVER ask for the X service, always check your maintenance guide, distill it down only to the things you need (like brake fluid flush or oil change, NOT any of their tests/checks/road tests) and ask them to do specifically those services. I learned this when I bought my car as well, I asked for the 60k service and they quoted me $1000+. Then I asked the same dealer for each required service individually and it came to $500 (it was this high because spark plugs are needed at 60k).
Sewell will become your best friend. Rotors are $150, pads are $55, and there's a detailed DIY thread already on CL. It's of course questionable if you need all those things, but if you do, you've saved $700 right there.
Why did you trade in your 335?
Op, welcome to CL!
All the info you need about everything is on this site. Learn to do maintenance yourself, learn to mod yourself, it will save you thousands, and its fun, and satisfying. The dealership will rip rip rip you off for everything!!! Good Luck, and nice Bimmer.
mosh12
07-02-14 12:55 PM
thizhkboi
10-05-13 08:20 AM
