how to install flyaudio in my 08 is250 w/fact nav. lots of pics.
your dealer is not looking up the right part number! however I do have an extra one laying around in case I have to do a oem nav swap to fly audio, for one of my customers or friends.
Mr. scientist.. do u still here.
i do need ur help
i have is250 11year with factory navi
biut the navi still is stupid, so i get a chinese aftermarket 8inch navi
How can i install the after navi in my car.
i have a wiring diagram but i am still trying to install for 4weeks..
there is no scientist like u in Korea. please help me...
It is the site including diagram too
http://cafe.daum.net/newtmax750/LbKG/4
i do need ur help
i do need ur help
i do need ur help
hi linus73. My navi is dead too. I have a 06 is250, and like to replace an flyaudio units. In order for me to install and use my flyaudio units, i have to remake the nav swap? the factory male J53 plug is from the car or the oem unit?
Please help linus73 if you can provide some direction would be appreciated. Also read you were able to keep the OEM backup cam with the install correct? Can you share some details on how you got it working.
Thanks
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
thanks! i figured out how to get it converted and uploaded, attachment at bottom.
my original factory nav unit was perfectly fine! i wanted dvd, but did not want to add a interface module or place a dvd player in the glove box. so i searched the cl forums and found only 1 other person who did it. his diagrams were good, but i was still confused a bit with some gateway wires, so i studied it real good and ordered a j54 plug from dealer
and installed some wires into the new j54 plug and tapped them onto the J53 harness that was on the side of the old nav unit without cutting anything! this way i can just plug in the original factory nav unit if i ever want to go back. only issue i ran into was the airbag light, which i could not figure out how to get it to go away. i even called a guy in canada who has done it and still no luck, so i just removed the cluster and put something over the led housing where the light was. you could never tell i have a airbag light on at all, and it doesnt cause any issues except that if an accident happend the passenger airbag would not diploy.( i am not responsible if you do the same and air bag does not diploy in a accident, do at your own risk! )
ISMAN1000
07-08-09 01:02 PM
