Brightest LEDs
Brightest LEDs
I'm looking to get new puddle and reverse lights for my 08 IS350...Does anyone know what would be the brightest white 5000k or 6000k LED bulbs (from VLEDs) that I could put in both? I have seen a few on the sight but I fear that some of the bigger ones might not fit in the light housing.
Thanks
Thanks
check out https://www.clublexus.com/forums/clu...rse-bulbs.html
there is a link in his signature for exterior lights... way better prices then vleds....imo, good luck bro
Cree seems good. They are more of a projection type so it would be likable who likes the projection look.
For me, I did not want cree so I went with JLC 's SMD(s) to have more of a even light distribution throughout the housing.
For reverse, you can go with the T10 9-SMD and the mirror, T10 5-SMD.
Former Sponsor
If you want the light to projector bright/far enough for you to see the road at night, CREE is the only way to go. But If you just want the reflector housing to be brighter to let other people see it, you can just get the 9-SMD LED, 13-SMD LED or higher. BUT make sure they will fit into your housing before you buy them!!!
nice carrrr
I recommended the 9-SMD because the 9-SMD's length because is about the same at the stock bulbs length. The 13-SMD I am not so sure if it will fit since it is slightly longer.
I haven't seen the CREE/JLC reverse lights in person, but by most accounts they seem to be the brightest lights available for that application.
For the puddle lights, I think V-LED high powered flanks hold the title for being the brightest: https://www.clublexus.com/forums/is-...de-w-pics.html
Former Sponsor
CREE LED is the brightest if you want to have the best output of the light!
jraiderg
09-11-16 02:29 PM
Joeb427
03-28-12 04:21 PM
