Backup Camera and Security Light don't work after putting Navi back in. Help Please
Hi all,
So I had a problem with my navi where the touchscreen stopped working due to a faulty connection. A friend of mine was able to fix it. I reconnected the navi and put it back in but now the backup camera doesn't work anymore and also noticed that when I lock the car, the Security light on the navi doesn't turn on. Is there something that I need to reset for these things or something else I should check for? I'm pretty damned sure i plugged everything back in. Also, putting the damn vent back in is such a pain. The bottom part of the vent doesnt seem to want to slide back into place.. grrr
Please let me know
Thanks!
Please let me know
Thanks!
check it out and i made a youtube video about the vents...
https://www.clublexus.com/forums/is-...avigation.html
http://www.youtube.com/watch?v=YF_JNaVTir0
thanks for the vid.. I did actually come across that when i was taking the vents out and it helped. The problem is putting the vent back in. It doesnt snap back into place very well. I can get the top to go in but the bottom part does want to snap back into place as if something is blocking it from sliding in. Thought I maybe had to lift it a bit or maybe the vent opening was causing it to not snap in because it slides in at an angle. Still trying to futz around with it but it's not going well
Freedom
11-27-16 08:14 AM
Makomagnet
08-24-14 04:47 AM
