IS-F / Sport Steering ECU
Old 08-30-12, 08:28 AM
  #151
RomeIS250
RomeIS250's Avatar
This is the second day having it, and even on normal mode steering is definitely heavier. Worth the money.
CHECK YOUR JUNKYARDS!!!
Old 08-31-12, 03:09 AM
  #152
yungsters
yungsters's Avatar
I got the 2012 IS-F ECU installed and calibrated on my 2006 IS350 two days ago. Granted that the ECU has not fully adjusted to my driving, yet, but here's my feedback so far.
In normal mode, the steering is slightly stiffer than what it used to be. As others have pointed out, with power mode, it is noticeable stiffer and requires more strength to rotate the wheel.
I remember reading somewhere in this thread a question about whether this can upgrade older models to switch into sports shifting mode while in drive when using the paddle shifters (like in newer models). The answer is no.
In my opinion, there is no difference in the shifting at all. Normal mode and power mode still affect the shifting and sensitivity of the gas pedal like it did before. For me, this only affected the steering wheel stiffness.
Old 08-31-12, 06:01 AM
  #153
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
There is no way this would affect anything but the steering. Not sure where you got the idea that it might.
Jeff
Old 08-31-12, 09:50 AM
  #154
Herofmine
Herofmine's Avatar
Also i took my car to highway and defiantly * steering wheel becomes more firmer on highway when car go faster.*
Thanks for Jeff Lange for openning this thread and for his advices.*
Old 08-31-12, 10:18 AM
  #155
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Yes the steering is almost as light at parking lot speeds, once you get above about 10km/h (6mph) is when you begin to notice the difference.
Jeff
Old 09-04-12, 11:01 AM
  #156
ALLCHILL
ALLCHILL's Avatar
Originally Posted by Jeff Lange
Yes if you had the Techstream Lite software and an adapter cable you can calibrate it yourself.
As for going to Lexus, I wouldn't even tell them that you put in one from an IS F or anything like that, just say you had your steering ECU replaced and were instructed to bring it to the dealer to get it calibrated. Not sure what they'll charge you. Probably 0.3-0.5 hours.
Jeff
I was just quoted $208 by Woodfield Lexus to have my new steering ecu installed and calibrated. That said, I think ill just install it myself and find a shop that uses Techstream Lite software.
Anybody care to do a DIY since I have no clue where to begin? I think someone mentioned new mounting brackets will be required going to an ISF ecu...
Thanks in advance
Old 09-05-12, 09:49 AM
  #157
Alantjai
Alantjai's Avatar
Still dont feel the difference between normal and ect power.....
Old 10-08-12, 06:09 PM
  #158
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Since you only have the F-Sport part and not the IS F one, I wouldn't expect any difference. Only the IS F one changes.
Jeff
Old 01-21-13, 02:13 PM
  #159
andrewshu3
andrewshu3's Avatar
Can someone please tell me how you're supposed to unplug the harnesses from the ecu?
Thanks!
Old 01-21-13, 02:29 PM
  #160
ohiois350
ohiois350's Avatar
Jeff
Jeff, the best part is to get the ISF steering ECU not the IS-Sport ECU right?
Old 01-21-13, 02:58 PM
  #161
circuitt
circuitt's Avatar
my car feels like that now on the freeway very numb, almost like I am steering a pirate ship. there feels like there's slop in the wheel.
I don't feel very confident at all @ high speeds in a bend with cars on either side of me.
Could a newer steering ESU help with this issue?
I have BC coils and sways in my garage ready to be installed, so I am completely stock on OEM NON-Sport suspension.
Old 01-21-13, 03:12 PM
  #162
RocketGuy3
RocketGuy3's Avatar
Sorry if this has already been asked, but this sport package ECU Is not compatible with pre-09 ISes, correct? Or would it work with my 07 IS350?
EDIT: Nevermind, I see it listed on the Sewell site as available for the 2007 in the F-Sport accessories question. So that probably answers the question... Probably not worth $440 + tax + shipping + installation hassle, though...
Old 01-21-13, 05:20 PM
  #163
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Yes, I find the IS F steering ECU to be the best choice.
It may be able to help, provided there's nothing actually wrong with your car that is causing the loose steering feel.
From everything I've seen/heard at the point it seems that all 2IS steering ECU's are functionally interchangeable without issue.
Jeff
Old 01-21-13, 11:07 PM
  #164
circuitt
circuitt's Avatar
I have a CPO so I might have the dealer take a stab at it. I definitely don't feel a connection to the road, (hard to explain) feels like maybe an inch or so slop, so say I am going 80mph on an S curve, first steering left holding that angle, then steering to my right, just doesn't feel very precise.
Old 01-22-13, 12:26 AM
  #165
reyoasian
reyoasian's Avatar
new item to my mod list!!
Quick Reply: IS-F / Sport Steering ECU
