IS-F / Sport Steering ECU
#166
is there a "how to" on how to replace? Do I need to disconnect battery? Where is it located? I just bought 89650-53081 - 2010 IS250/350 Sedan with Sport/F-Sport/X-Package ECU, but when it gets here I will have no idea where how to do this....
Also does it need to be dealer calibrated or does it do it on its own--there seems to be a debate here...
Thanks
Thanks
#167
if you bought it from a dealer it will have no calibration at all. in this case most your power steering most likely will not work at all.
if you bought it used, then it already uses the calibration from the other vehicle. You could use that calibration, but its still not calibrated for your car. in this case, your ps will still work.
to calibrate you need techstream, or a technician with it that can calibrate it for you.
#168
#169
I'm quite interested in swapping the IS F ECU into my car, first a simple question:
Has anyone had issues with calibrating the steering ECU using the ~$25 eBay cable & Techstream software?
Also, I'm not going to be able to do this mod for a while, but I did some searching online and found a used ISF ECU (89650-53040): http://www.alltoyotalexusparts.com/s...s-f/61301.html Somebody call and grab that thing up! You're welcome!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#170
Also, I'm not going to be able to do this mod for a while, but I did some searching online and found a used ISF ECU (89650-53040): http://www.alltoyotalexusparts.com/s...s-f/61301.html Somebody call and grab that thing up! You're welcome!![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#173
1. Stock suspension with IS-F ECU
2. Stock suspension with coilovers (any brand)
Wondering which has a greater affect on feedback. I know coilovers affect the ride a lot more, and the ECU steering feel, but overall which gives better handling feedback.
#174
I didn't see anyone (aka Jeff Lange) answer this question...did I miss it somewhere in the thread? This thread is awesome! However, wondering if the money would be better spent towards coilovers. Has anyone compared the following:
or your view from the seat so to speak. The ECU, or anything having to do directly with the steering, will affect how you feel it in your hands. The IS steering is electric, so the ECU and any weights, or lack thereof, in the steering wheel is what you feel in your hands. People often talk about the incredible feel of the steering in a BMW, especially the reviewers. This is now hooey, as BMW's are now also electrically assisted. They feel like the old cars actually ran.
So Lexus based on a lot of customer feedback sought to give drivers more of a sports car "feel" in the steering wheel. Hence the ecu. It doesn't actually make the cars handle any differently as coilovers, sway bars, etc would. It's all a matter of feel and feedback that you may or may not want.
#178
I must say, the ISF Steering ECU is night and day. Makes my IS feel more like the BMWs I have been test driving and less like my wife's Sienna. Of anything I have done, this is the most fun. (the rear sway is a second--great combo)
Last edited by DaveGS4; 09-02-13 at 02:33 PM. Reason: Please use classifieds for FS
