IS-F / Sport Steering ECU
Old 05-02-16, 11:20 AM
  #241
shyguyF
shyguyF's Avatar
For those still having the communication errors when trying to calibrate - clear the DTCs first. The factory service manual is very clear about needing to do this first. I had the same issues, then read the content on TIS and it went like butter.
Hi Lobux !
I'vejust got a ending 42 steering ecu to upgrade for my 08 ISF. I would like to calibrate the new ECU myself . Can you let me know what does the DCTs stand for as you mentioned above ?
Thank you in advance!
Old 05-03-16, 12:16 PM
  #242
WylieKylie
WylieKylie's Avatar
Diagnostic Trouble Code
Old 05-04-16, 01:02 PM
  #243
shyguyF
shyguyF's Avatar
Thank you Wylie !
Old 08-27-16, 02:18 PM
  #244
buister
buister's Avatar
Is there any difference between 41 and 42 when installed in the IS350 in terms of performance?
Old 09-06-16, 05:50 PM
  #245
bangdangvn
bangdangvn's Avatar
Hi-
any insights to getting the 3 connectors off? Looks like there are two with white interlocking mechanisms
Old 01-14-17, 03:36 PM
  #246
edhohoho
edhohoho's Avatar
Default ISF steering ECU upgrade on IS250/350
I was wondering what IS250/350 owners think of this upgrade because it seems that mostly only ISF owners have done it. From what I have read it gives a firmer feel to the steering wheel above a certain speed, making the steering feel more precise/less vague, and giving the driver more road feedback.
Also, I live in Los Angeles, any recommendations on dealerships that will calibrate it using Techstream? Heard some people have run in places that won't do it. Also read that people have gone to Longo with success. Is there anyone I should ask for over there specifically? Thanks.
Old 01-14-17, 06:34 PM
  #247
Zmon
Zmon's Avatar
Lexus tweaked the ECU throughout the years (08-10 part number 89650-53040, 11-12 pn 89650-53041, and 13-14 89650-53042). Not sure what entirely changed through the years, but the most sought after ones are obviously the newest ones (11+) which would benefit older IS-F's. As for us 250/350 owners, many of the people here did it and thought it was one of the best things they've done for their handling. If you buy a used ECU, you most likely won't have to calibrate it (of course your mileage may vary). I just bought a 12 ECU a couple weeks ago, was just plug and play no calibration necessary. New ones will need to be calibrated, which any Toyota or Lexus dealer can do. You can do it yourself if you can obtain Techstream as well. I can't really comment on the 12 ECU yet, I only had a day of testing it before I had to garage it to replace a sensor.
Consider going through this thread for more info.
Also, maybe consider tossing on the IS-F steering damper (info). (damper part number 45713-53020, and you need two screws part number 90159-50199)
Old 01-15-17, 09:03 AM
  #248
edhohoho
edhohoho's Avatar
Thanks for the great information. I did read about the three different ECU models available and already have the steering damper. I've read that people have used a new ECU for a little while before going to a dealer for calibration. Hope this is the case because I may try to install it myself in order to avoid additional costs for this upgrade.
In that one day of testing did you notice any significant difference? I really hope to hear more about your experience with the 2012 ECU on your 350 once it's back up and running. By any chance dis you already upgrade the LCA bushings?
Old 01-15-17, 09:21 AM
  #249
Zmon
Zmon's Avatar
AFAIK, you'll have no power steering with a brand new ECU, as it isn't programmed. A used one will already be programmed and should work out of the box.
Errrrr.... Definitely need more testing to really say anything. I drove it around a few blocks in Chicago at 30mph, so I can't really say too much. Did feel a lot firmer though. As for my suspension, it's stock except for a rear sway, been putting off the other things.
Old 01-16-17, 08:14 AM
  #250
getafewliv
getafewliv's Avatar
I had the 2012 ISF ECU in my 2006 IS350 and it was an excellent mod! The ECU paired with the steering damper and F Sport rear sway bar completely changes how the car feels and drives. Absolutely worth the money...
Mufis (01-12-18)
Old 01-16-17, 01:16 PM
  #251
edhohoho
edhohoho's Avatar
Originally Posted by getafewliv
I had the 2012 ISF ECU in my 2006 IS350 and it was an excellent mod! The ECU paired with the steering damper and F Sport rear sway bar completely changes how the car feels and drives. Absolutely worth the money... I also happen to have one for sale pre-calibrated!
Thanks, that's great to hear! I already have all the other stuff, waiting for the ECU to be delivered.
Has anyone been able to figure out what, if any, changes were made between the 2011-2012 and 2013-2014 ECUs?
Old 01-16-17, 04:22 PM
  #252
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
At the very least, they have a different part number printed on their label, haha. I haven't done any testing with the newer steering computers. I have the 11-12 in mine and have been very happy with it.
Jeff
Old 01-16-17, 07:25 PM
  #253
edhohoho
edhohoho's Avatar
Jeff
Not to mention a $200+ dollar price difference!
Aside from steering feel, does the ECU provide any physical handling improvements like those conferred by sway bars and struts/springs? I've never had a chance to drive a BMW so it's hard for me to imagine how the feel of the steering wheel movements translates into perceived performance.
Old 01-16-17, 08:27 PM
  #254
ohiois350
ohiois350's Avatar
So like you guys said if i buy the used ISF steering ecu, I don't have to take to a dealer to get a calibration? Just plug and play? Thanks
Old 01-16-17, 09:21 PM
  #255
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I would still definitely recommend doing the calibration whether you get a new or used steering ECU.
Jeff
Quick Reply: IS-F / Sport Steering ECU
