IS-F / Sport Steering ECU
#346
Salvage yards usually give you some type of limited warranty. I bought my first ISF steering ecu (from a 2010 ISF) from a salvage yard and it worked fine. They are built very durable and can withstand punishment. Inspect it to make sure there isn't any physical damage. If not, it should be fine. If it's busted up, don't buy it
AMIRZA786 (10-13-20)
The following 2 users liked this post by flowrider:
AMIRZA786 (10-14-20),
chouavue10 (10-14-20)
#351
The following 3 users liked this post by kenji211:
The following 2 users liked this post by MikeFig82:
#353
My point is this; although no one has had a failure, eBay purchases come with risk just like buying a used car that there could be a latent failure induced to the EPS unit (or anything else electronic) by careless people.
FWIW my 041 unit is in its 3 vehicle.
The following 2 users liked this post by 2013FSport:
#354
The known risk is some idiot in the past doing a repair or battery swap, connects the battery leads backwards. One of the primary fuses to take a hit is the EPS ECU 80 AMP FUSE. What this says about Yoda engineering is you can't have steering assist failure and cause a wreck killing people as it it highly frowned upon so they protected the *#*# out of the EPS ECU. As such, they placed protective fast acting high amperage reverse polarity diode in the device to protect it from STUPID mindless acts of failed battery installs.
#355
so I'm gonna sell this ecu I just bought as my wife(boss) says we dont need to change it sincer it will be ber daily and likes it already....soo have not tried to see if it works yet since it is still shipping here but upon arrival will sell $320 plus shipping. let me know guys. dont know if it works or not as I wont even install it.
![Driving Skid](https://www.clublexus.com/forums/images/smilies/drivingskid.gif)
The following 2 users liked this post by AMIRZA786:
2013FSport (10-14-20),
The following 2 users liked this post by chouavue10:
#357
If you want more stability and less nannies as you like to push it, play, then toggle on ECT. It will firm up the transient road inputs that try to move the car and just let you do your thing. As stated by many before me, it does offer a greater range freedom to play while also reducing concerns/inspiring confidence, as if everything is OK, which it is...
If you are inspired by driving, get the 89650-53041 IS-F EPS unit.
#358
#359
I have not confirmed this, but I don't think the F-Sport EPS ECU may work for him. I read in the notes that F-Sport suspension is required for that ecu. He has a 2006
