High beam replacement from HIDextra
HIDextra 6k's don't match Garax 6k's. The HIDextra's are a little bit more blue. It know there's a difference between the projector headlight housing and the regular fog light housing, but its noticeably different. 6K V-LED's go good with the Garax 6k's tho. Also, one of the ballast's i got from HIDextra is dead already ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
After you put in your V-led drl, do you have control over it to turn it on and off? Did you also change your parking light ?
Also, one of my V-LED parking lights died last night. I noticed the front firing LED's are dead and the radial firing LED's are very dim on one side. They should be replacing them, but still, i never had issues with V-LED's before don't know why i am now
anyone have any suggestions on a high beam replacement to match garax 6k HIDs and VLED 6k parking lights. I don't want to go the VLED route because i want high beams still.
i currently have silverstar ultras but it still looks like crap i think
What about something like this. http://www.blitzpowerusa.com/product...e_halogen.html for the high beams.
maybe someone has tried them and can give pics or a review.
Brociouz has good lighting reviews ill ask him if he's heard about these
id be very interested to see how these work in person but $100+ plus is a little much for 2 bulbs. also i don't see a 9005 bulb listed on the site.
Have you tried the bulbs on the link you provided...
But then again running this bulbs with lower voltage like DRL does might change the color output.
