Burnt LED instrument needles
Old 12-05-11, 11:53 AM
ssis300
ssis300's Avatar
Damn.... how random. I went to lunch just now and noticed my tach needle is dimmer in the middle portion! Crap!!
Old 12-16-11, 04:35 PM
johnblagg
johnblagg's Avatar
I just went to o-rileys and bought led strip lights that can actually be cut into sections and pulled the tach needle and used clear silicone caulk to glue the 3 led section into the needle after pulling out toe old burnt out original .....pushed it back on and whoot a green illuninated tach needle.Tomorrow the rest get used as backlighting to make up for dim ccf tubes
Old 09-24-14, 12:19 PM
farhaadp
farhaadp's Avatar
Default hi ppl
here is the speedo needle led board specs
i replaced my leds,(0603)
the needle housing was a mission to remove,flathead screwdriver will work,you need to pry on the clips,see attached photos
cheers
Attached Thumbnails Burnt LED instrument needles-imag0573_burst002.jpg   Burnt LED instrument needles-imag0574.jpg
Old 06-25-19, 09:00 PM
gixxxer69
gixxxer69's Avatar
Originally Posted by chi123
If you know how to solder LEDs onto the needles, you can easily do so. They can use either a 1206, 0805, or 0603 size LED. It'll cost you just $5 to repair it yourself if you don't mess up. Otherwise, I'd be glad to fix it for you and even change the color of the needles if you want.
@ chi123 do you still fix instrument cluster needles? Have you ever made a video? I am comfortable soldering and taking the dash apart but have never done needles LED
Old 06-26-19, 04:32 PM
Drivers408
Drivers408's Avatar
Here a video I found 2 years ago when I was going to do mine. Luckily I didn’t have to and got them replaced by lexus under my warranty. Hopefully this will help. Good luck!
Old 11-21-21, 12:35 AM
ErwinLit
ErwinLit's Avatar
Default What specific blue did you use?
Time to revive this thread!!
My 2010 Lexus IS-F needle burnt out.
The video I watched stated he used a GQ1206 Right Angle Blue LED which is now unavailable. I can't find any substitute. Took me alot of hours researching from Jameco, Digi-Key and Mouser. I guess I shall use a regular 1206 SMD.
1206 LED package specs
min-max voltage: 2.8-3.2V
dimension: L3.2*W1.6*H0.9mm
What Wavelength (color)
Blue wavelength is 450nm and i see packages with with 430nm (super blue) and 470nm to 475nm
Links
Video:
LEDs: https://www.mouser.com/c/optoelectro...ct=Blue%20LEDs
Retroplay
07-28-18 08:34 PM
MrBigNasty
SC- 1st Gen (1992-2000)
06-04-17 12:17 AM
howler
11-13-13 03:04 PM
21ce
16
03-02-09 04:39 AM
Quick Reply: Burnt LED instrument needles
