HID Fog light problems
My hid fog light on the passenger side goes on and off. It would only work sometimes and when i drive for a while it would go off. I was wondering if anyone else has this problem or if anyone knows what is wrong with my fog light. Im not sure if its just the wiring, the bulb, or if i need a new ballast. I had the wire tightened a while back but it still has the same problem. Any advice would be much appreciated, Thank you!
3-4 years is quite some time for most HID bulbs, probably just a bad bulb if you've had no issues till now.
You can always swap the right and left and see if the problem continues. If the drivers side fog lights starts failing afterwards, its the bulb. If the passanger side still does it after the bulb swap, its either the wiring to the ballast or the ballast.
Registered User
1-check connections(if connections are good, then move to 2)
2-switch driver side bulb to the passenger side
>if bulb stay on without shutting off you've found your problem. New bulb is needed
>if bulb goes on and off then a new ballast is needed
hope this helps.
hope this helps.
Former Sponsor
Rolando
09-05-11 05:03 AM
