max drop without fender work
12-05-11, 11:57 AM
what is the max drop without and moddin your fenders? rolling acceptable
please help! thhank you!
12-05-11, 12:17 PM
Stating the wheels specs here will help you get the answer you are looking for.
I can drop the car to the floor if the offsets fit, and there will be wheels that wont fit even on stock suspension.
BTW I have done nothing to my fenders except roll the rears
12-05-11, 12:22 PM
Depends on a variety of factors - wheel offset, wheel width, wheel diameter, tire size, etc
There is no "max drop" that is universal for everyone though
12-05-11, 01:19 PM
need to know wheel and tire specs.
12-05-11, 01:41 PM
19x9.5 front 235 40 19
19x10.5 rear 245 40 19
+22ofset
12-05-11, 01:42 PM
12-05-11, 01:52 PM
to run those widths with absolutely no fender work whatsoever, you'll need wheels with offsets in the high 30s.
you'll also need to run 35-series tires, because those 40-series tires will be too tall.
btw, fender rolling = fender "modding".
12-05-11, 02:07 PM
that 235/40/19 will be too much tire for the front. you will need to roll the fender and go with 225/35/19
12-05-11, 02:07 PM
would u mind stating what wheels you are looking at?
12-05-11, 02:09 PM
thinking of rocking the varrstoen 2.2.2
12-05-11, 02:15 PM
12-05-11, 02:22 PM
Hmm. I'm about to get some 19s.
19X8.5 front
19X9.5 rear
Keeping OEM overal diameter with tires, what's the max drop without any fender work including rolling fenders?
12-05-11, 02:29 PM
^ offsets?
u should be able to drop about 2" but depending on offsets
12-05-11, 02:36 PM
^Thanks. 35 front, 38 rear or 38f, 45r depending on the 2 wheels I'm looking at. Don't wanna go too aggressive.
12-05-11, 02:56 PM
both offsets will work and you can go with a 2" drop. I would go with the 35-38 instead of 38-45.
The higher offsets will look sunken in pretty bad.
