XM satellite radio?
Old 12-28-11, 01:50 PM
RamJam
RamJam's Avatar
Lightbulb
Sorry, the second link keeps coming up wrong. Try this one. If it comes up wrong just type 86100-0W220 in the search box and it will find the Mounting Kit
http://www.factorypartsexpress.com/p...catalogid=5503
Old 12-28-11, 02:51 PM
Kurtz
Kurtz's Avatar
Originally Posted by RamJam
Brand new to the forum and and happy to be a part of the group. I've been researching the OEM XM parts for my IS 250 also and just recently stumbled upon these two links to buy the parts new. I haven't placed my order yet, so I may get to the checkout only to find out they aren't available, but thought I would share the links on the forum just in case. Anyway, here they are:
http://www.toyotapartsmall.com/produ...p?part_id=938#
I strongly suspect you'll find they're not available when you try and order.
Old 01-03-12, 10:55 AM
rsg
rsg's Avatar
I am finding some XM tuners that are made for Scion but are compatible with the Camry part number 86180-0W030, which is the same as the part number for the IS. Do you think this would work?
Old 01-03-12, 11:22 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
That is the correct tuner, however it is the IS-specific fitting kit that is discontinued.
Jeff
Old 01-03-12, 01:22 PM
rsg
rsg's Avatar
Has anyone had any luck in buying an XM receiver/fit kit for the IS? I am following up on a few leads and will post here if I find any success. I bought the Vaistech tuner not knowing I would have to remove the head unit (which I do not want to do--I caused some damage just dealing with removing the trunk trim).
Old 01-03-12, 01:27 PM
ISX50URRA
ISX50URRA's Avatar
I cant stand FM radio. OEM XM is that way to go!! search on ebay you should find it there .
Old 01-03-12, 01:33 PM
whitebeast
whitebeast's Avatar
Search on ebay or google it. You could find one
Old 04-16-12, 04:55 PM
diverchris
diverchris's Avatar
Hello,
I was looking at this thread with interest. I looked on Sewells website, I know the part has been discontinued, but under the instal PDF the part number is listed as 86180 0w030. This is the same part number listed on Toyota Parts Mall. So I called to see if they had it in stock. I was told that this part number has been replaced by part 86180 0w032. My question now is will this part number work with my 09 IS250.
Thanks in advance,
Chris
Old 04-16-12, 06:28 PM
Jay954
Jay954's Avatar
i am in the same boat i just started looking into it today
Old 05-02-12, 07:51 PM
Dimitri
Dimitri's Avatar
wow, thanks guys! Did anyone confirm if it will fit or not?
Old 06-19-13, 12:15 PM
rjmilne
rjmilne's Avatar
Default XM Wiring Harness and bracket found!
oemlexusparts.com has the wiring harness, bracket and antenna there. i just bought a full set. It set me back almost $200 but it is available for those looking to buy them. I bought my XM receiver off ebay for $74 and it was brand new. A little costly for XM but it's all worth it now.
The parts aren't listed as any part #'s I've seen before. I'll post them when I get back from my business trip.
Old 06-19-13, 12:38 PM
UniSlayEX
UniSlayEX's Avatar
Okay. Give us the part number when you get back. Thanks
Old 06-20-13, 07:18 PM
s6 4rings
s6 4rings's Avatar
curious too
Old 06-26-13, 03:20 PM
rjmilne
rjmilne's Avatar
Default XM Radio Part #'s required for Lexus ISX50
Ok guys here they are. The phone # is 1-855-739-2022. The parts guys name is Alex. Super nice dude who will go out of his way to help you. The parts are currently on sale so get em while you can.
Lan Cable kit to connect amp to XM tuner and cars harness is PT54653060CK $141.76
http://www.partswebsite.com/oemlexus...4653060CK.html
Bracket to mount it to the car is PT54653060BK $21
http://www.partswebsite.com/oemlexus...4653060BK.html
Antenna is PT54653060AK $48.75
http://www.partswebsite.com/oemlexus...4653060AK.html
Costs a little more than the kit as a whole when it was sold but this is really you're only option now. Took days of research to find this info calling multiple dealers around the country.
XM Radio Module is either 86180-0W030 or 86180-0W031. $165. I have bought 2 of the *31 modules and they work great. Even got 3 months free because they had never been activated.
http://www.partswebsite.com/oemlexus...61800W031.html
Old 01-11-16, 01:09 PM
raulrokz
8th Gear
raulrokz's Avatar
Has anyone tired this successfully?
I'm curious to know if this actually works.
Vsingh93
ES - 6th Gen (2013-2018)
06-29-19 02:41 PM
iameric
12-15-07 05:35 AM
Quick Reply: XM satellite radio?
