Gas wont fill up all the way.
Old 12-15-11, 11:45 AM
  #31
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by Sango
Probably it would make better sense to change the indicators to make E as 1/4 because only users can use 3/4 of the tank since it can cause life span issues for the pump.
I'm not saying that it causes all sorts of failures, but, it should be a well known fact that most electrical and mechanical pumps (and other devices) benefit from running at a consistent temperature and from preventing getting too hot... how hot is too hot, I don't know for sure, but fuel pumps definitely fail, and one way to help them keep cool is to not run a fuel tank too low...
Old 12-15-11, 11:53 AM
  #32
andy23
andy23's Avatar
Default Nissan Have the same problem with MTE
Here is the link with to nissan forums. These people have the same problem with the mte like mine. Check out the link. Hello everyone.
http://thejukeclub.com/topic226.html
Old 12-15-11, 12:17 PM
  #33
Toymota
Toymota's Avatar
Originally Posted by Kurtz
This hasn't actually been true on most Lexus/Toyota cars since at least the Mk4 Supra in the 90s... they designed a small fuel resivoir the pump sits in to keep it cool, so that you can go well below 1/4 tank and have no problems.
I'd still go ahead and fill up at least by the time the light comes on, but you're not gonna harm your fuel pump going under 1/4 tank.
Lobuxracer has posted some pics from TIS showing the system in the past if you wanna search on it.
omg! The search function actually works!
Post #23 and #24: https://www.clublexus.com/forums/is-...ccuracy-2.html
Old 12-15-11, 12:28 PM
  #34
Kurtz
Kurtz's Avatar
Exactly!
As you can see back in 2007 I was doing the same "OMG! run under 1/4 and you risk killing your fuel pump!" thing because I didn't know about how Lexus/Toyota had engineered around the problem back in 1993... Lance was kind enough to correct me, and I've been paying that forward since
Old 12-15-11, 12:37 PM
  #35
andy23
andy23's Avatar
Still doesn't explan how to fix the issue.lol "toymota"
Old 12-15-11, 01:14 PM
  #36
jgr7
jgr7's Avatar
Filled up today in my new 2012 IS350C @ 1/4 tank on the guage only took 12.8 gal MTE was 58. Seems normal to me.
Old 12-15-11, 03:16 PM
  #37
Toymota
Toymota's Avatar
Well if you read the posts in this thread, you'll see that most people are trying to tell you that you don't have an issue. Everything is normal.
Old 12-16-11, 11:52 AM
  #38
laobo979
laobo979's Avatar
Here what it should be on a fill up. Since i was low on gas i drove till the light came on. As you can see top off is 14.5 gal same as the day i bought it. Never top off at 17 gal.
Old 12-16-11, 05:44 PM
  #39
andy23
andy23's Avatar
I still think there is an issue with it. How come I can pump up to 17 gallon when on E but now I can't. that is my question. I did it before for years but all of the sudden I can't. That is wierding me out.......
Old 12-16-11, 05:48 PM
  #40
andy23
andy23's Avatar
Default mte
so when you finish filling it up. Did you check you MTE. What was it please. Thanks!
Old 12-16-11, 06:28 PM
  #41
Vroomin350
Vroomin350's Avatar
Never seen anything past 300 on mine, if you've always been filling up 17 gallons, something tells me you've been letting that tank clean itself to chrome every time.
Old 12-16-11, 06:42 PM
  #42
mitsuguy
mitsuguy's Avatar
Exactly!
That is good information, for sure... Both confirms that it is/was an issue, but also that it isn't a worry anymore...
Still no reason to try and use every last drop of fuel...
Old 12-16-11, 08:31 PM
  #43
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,973 Likes on 2,403 Posts
Originally Posted by dackp143
Disconnect your battery for 20 minutes. Reset everything, start over. I don't go by my MTE, I use the trip meter. My MTE says 0 miles till empty and I can go another 40+ miles.
NO! This is the worst way to do this.
Read. Learn. Stop doing bad things (unless you're a masochist.) See 3. (a) (2).
Old 12-16-11, 08:39 PM
  #44
laobo979
laobo979's Avatar
Got 320 in the tank after i filled up. I drive alot of city so I won't get 400 a tank like my buddy 250 he does all highway.
Old 12-16-11, 10:12 PM
  #45
KillaIS250
KillaIS250's Avatar
My miles-to-empty always says between 420-460 whenever i fill up a full tank.
Quick Reply: Gas wont fill up all the way.
