Need tire size
I'm running 235/30/20 on my 20x8.5. Another member with your size rims posted the same tires as me as well on another thread where that OP ran bigger tires and had rubbing issues. I'm dropped 1.25 on megan springs fenders aren't rolled nor did I mod my fender liner. No rubbing issues at all. Any lower or if i had spacers I'm sure I would have issues
Going to need a stretch to fit right. I'm assuming your fenders are rolled too or your planning on rolling them?
For minimal strech your looking at something like 235/30/20F & 275/30/20R....i'm just not sure how that would fit tho, especially the rear. I would at least run some stretch on those rears.
you have to run semi-stretched tires with your posted rear wheel specs (moreso in the rear than the front).
btw, plan on fender modifications in the rear with 10.5 +27. you might be able to squeeze in 255/30-20 if you do.
if you read their posts, you can probably figure out what sizes YOU need to run. but since you don't care for their answers... it's 225/30-20 + 245/30-20.
i hope you're asking questions and not answering them, because 235/30-20 + 275/30-20 on 20x9/10.5 is not just a minimal stretch, it's called spongebob squaresidewalls. as in, those sizes would have such square (upright) sidewalls that they would do a number on the fenders and/or the tires on suspension compression. you'd have to run super-stiff spring rates to minimize suspension travel, which would turn the ride into crap.
