Is this the one with the 3m tape? or with the tabs? Also, the site that OP provided is for the isx50? 06-12' are the same correct? Tempted to buy it, but need clarification.
The AVS and JDM ones both use double sided tape. The JDM visors have little clips that hook on the door trim, whereas AVS visors dont. $80 is pretty cheap for a set though.
Pics. JDM is better but this isn't bad for the price. Got mine $115 shipped.
Originally Posted by istarzan
Just installed mine. Indeed there is a fitment issue with the tab that goes into the mirror plastic, where the visors meet the mirror plastic thingy. It wouldn't fit flush. I had to dremel about a inch off the tab and now it fits perfect.
280? for another $20 u couldve gotten the JDM ones
Yeah, I took a gamble on shipping (not knowing the size and weight of box), seller to shipping forwarder was same price as everybody else but forwarder to me initially was $250 but repacked to $160.
To put mine on I had to saw off a portion of the tab to fit perfectly, chrome bit is not well made (stuck on to the visor with tape), and 2 of the visors sit very close to the window (I think someone else had an issue with window hitting the visor when closing).
It does look good though
Pics as promised. BTW, you do not need to cut/Dremel anything unless you feel like you want to. It just takes a little prying with a flat head screwdriver along the edge of the black corner plate to expose the area for the tab to settle in.
DO NOT use a screw driver! Lower window down and the tab will slide right in easily!
