so i forced my way into buying these wheels at a great price and ended up regretting it.
I currently am running 19x8.5 +35 in the front with a 5mm spacer to clear the brakes on my 06 is 350. the tires are 235 35 19 and the tires rub on the back of the wheel well. BTW THE CAR IS STOCK SUSPENSION NO DROP.
Should these specs be rubbing? any suggestions how can i fix it?
should i go to 225 on the tires or what can i do? appreciate the help
heres an old pic of the car with wheels tooo
they dont rub the fenders they are rubbing the plastic tire well so i feel like i have to go with smaller tires or the place i got hte wheels from sold me the wrong offset of the wheels
You've pretty much answered your own question lol. Yes it's the fender liner, and projectdna is right, by running the 5mm spacer your are effectively running a 30mm offset
Smaller tires and rolling the fender liner will alleviate the problem
it's not a big deal that it rubs.. you'll get used to it!
So did your overall wheel+tire diameter increase from stock? I'm still running stock 18s and want to upgrade to 19s and drop 2 inches. But I'll try to keep OEM diameter to avoid rubbing.
Honestly no matter what anyone says. stock sizes are usually the best as far as performance. the 18 set up stock is perfect for the track. Im trying to purchase a set of oem 18s
Did the 235 tires come with the rims? 225 / 35 is what you should have with 19's
I'm not convinced that the stock 18's would be the best for the track. I would think a lighter and wider wheel would be ideal. BUT I don't kno anything.
