08' IS250 AWD Engine Coolant Leak, How Bad?
did some reading on the forum and does not appear to be a leaking hose as the fluid is all caked at the cap and on the engine. i do not have access to presurize it so am asking what do you guys think before i take it in to the shop. also, the oil is NOT milky so it's not mixing.
as you can see from the photos that the engine coolant is caking around the cap and seems to have leaked down the container. (photo 1)
what i am concerned about is that it seems to be coming out of something in the engine bay. (photos 2 & 5)
photos 3 & 4 show area where i see the pink caked on too.
any ideas before i take it in on how bad this is going to set me back? i added cup of water since i was an inch below the minimum.
thanks!
thanks!
yup, i took the car in and it ended up being the water pump. covered under the powertrain!
however now i have a knee airbag issue which i posted up in another thread.
