service history
Old 01-01-12, 11:05 PM
Shervin021
Shervin021's Avatar
Default service history
het guy as you know i purchased my car used and this this the service history do you guys see anything odd or any recall that hasnt been done? and what is DISTRIBUTOR/HDLIGHT/T. SGNL DISTRIBUTOR/HDLIGHT/T. SGNL????
Dealer Reported 07/11/2011 Westside Lexus 49621 0937854 NON WARRANTABLE OPERATION CODE
Dealer Reported 07/11/2011 Westside Lexus 49621 0937854 WORLD CLASS INSPT'S
Dealer Reported 07/11/2011 Westside Lexus 49621 0937854 DISTRIBUTOR/HDLIGHT/T. SGNL
Dealer Reported 07/11/2011 Westside Lexus 49621 0937854 OTHER NON-OEM ACCESSORY INSTALL/R&R
Dealer Reported 02/23/2011 Westside Lexus 45615 0912313 STATE INSPECTION
Dealer Reported 02/23/2011 Westside Lexus 45615 0912313 ENGINE OIL
Dealer Reported 02/23/2011 Westside Lexus 45615 0912313 WORLD CLASS INSPT'S
Dealer Reported 02/23/2011 Westside Lexus 45615 0912313 VALVE SPRING REPLACE
Dealer Reported 02/23/2011 Westside Lexus 45615 0912313 FUEL PRESSURE SENSOR
Dealer Reported 08/31/2010 Westside Lexus 40719 0879496 40000 MILE SERVICE NON
WARRANTY-NON OEM
Dealer Reported 08/31/2010 Westside Lexus 40719 0879496 WORLD CLASS INSPT'S
Dealer Reported 05/14/2010 Westside Lexus 35637 0858621 35000 MILE SERVICE NON WARRANTY-NON OEM
Dealer Reported 05/14/2010 Westside Lexus 35637 0858621 WORLD CLASS INSPT'S
Dealer Reported 05/14/2010 Westside Lexus 35637 0858621 INSPECT BRAKE PADS & DISKS
Dealer Reported 05/14/2010 Westside Lexus 35637 0858621 IS ACCL PEDAL
Dealer Reported 01/20/2010 Westside Lexus 30826 0836388 OTHERS
Dealer Reported 01/20/2010 Westside Lexus 30826 0836388 NON WARRANTABLE OPERATION CODE
Dealer Reported 01/20/2010 Westside Lexus 30826 0836388 WORLD CLASS INSPT'S
Dealer Reported 01/18/2010 Westside Lexus 30803 0836042 30000 MILE SERVICE NON WARRANTY
Dealer Reported 01/18/2010 Westside Lexus 30803 0836042 STATE INSPECTION
Dealer Reported 01/18/2010 Westside Lexus 30803 0836042 BATTERY BATTERY
Dealer Reported 09/14/2009 Westside Lexus 25923 0811695 WORLD CLASS INSPT'S
Dealer Reported 09/14/2009 Westside Lexus 25923 0811695 25000 MILE SERVICE NON WARRANTY-NON OEM
Dealer Reported 03/12/2009 Westside Lexus 20268 0777313 WORLD CLASS INSPT'S
Dealer Reported 03/12/2009 Westside Lexus 20268 0777313 FUEL DELIVERY PIPE
Dealer Reported 03/12/2009 Westside Lexus 20268 0777313 REAR CALIPER INSP.
Dealer Reported 03/12/2009 Westside Lexus 20268 0777313 20000 MILE SERVICE NON WARRANTY-NON OEM
Dealer Reported 10/14/2008 Westside Lexus 15302 0749272 DISTRIBUTOR/HDLIGHT/T. SGNL DISTRIBUTOR/HDLIGHT/T. SGNL
Dealer Reported 10/07/2008 Westside Lexus 15138 0748308 OTHER NON-OEM ACCESSORY INSTALL/R&R
Dealer Reported 10/07/2008 Westside Lexus 15138 0748308 FRONT WHEEL ALIGNMENT
Dealer Reported 10/07/2008 Westside Lexus 15138 0748308 10000 MILE SERVICE NON WARRANTY-NON OEM
Dealer Reported 02/26/2008 Westside Lexus 10220 0707234 NON WARRANTABLE OPERATION CODE
Dealer Reported 02/26/2008 Westside Lexus 10220 0707234 CP CARWASH
Dealer Reported 02/26/2008 Westside Lexus 10220 0707234 20000 MILE SERVICE NON WARRANTY-NON OEM
Dealer Reported 09/05/2007 Westside Lexus 5826 0674612 NON WARRANTABLE OPERATION CODE
Dealer Reported 09/04/2007 Westside Lexus 5813 0674549 LEXUS ROADSIDE ASSISTANCE
Dealer Reported 08/15/2007 Westside Lexus 5297 0670948 5K MILE SVC
Dealer Reported 08/15/2007 Westside Lexus 5297 0670948 1,000 MILE SERVICE
Dealer Reported 02/28/2007 Westside Lexus 1704 0638308 NON WARRANTABLE OPERATION CODE
Dealer Reported 11/24/2006 Westside Lexus 6 0624951 NON-OEM WINDOW TINTING
Dealer Reported 11/20/2006 Westside Lexus 6 0622841 PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
Dealer Reported 11/20/2006 Westside Lexus 6 0622841 STATE INSPECTION
Old 01-02-12, 01:19 AM
JohnLX300
JohnLX300's Avatar
I had the "DISTRIBUTOR/HDLIGHT/T. SGNL " on my service history, and after I looked it up at the dealer, the service advisor told me that they use that code for warranty stuff so they can push extra warranty work on the vehicle about stuff we complain about!
Old 01-02-12, 09:00 AM
KillaIS250
KillaIS250's Avatar
It's had the valve spring recall and fuel leak recall done, so that's good. I don't see a dash rattle TSIB being performed anywhere in that service history, so check to see if you can hear any rattling from the dash. It's covered under warranty up to 4yrs/50k miles, since the last service was right before 50k, i'm assuming car is out of warranty (past 50k) at the moment. Also, looks like you got a 350, so you want to have the start up noise/cam gear TSIB performed too. Not seeing that on your service history, but its covered under the power train warranty (6 yr/70k miles) so if your still under that warranty, might want to try and get it performed.
Old 01-02-12, 09:17 AM
jbjones85
jbjones85's Avatar
+1 on all of this.
galvatron
03-21-18 09:53 AM
mtghlp
ES - 5th Gen (2007-2012)
05-24-17 05:17 AM
tjschraf
07-29-12 08:53 AM
teCh0010
05-24-12 05:45 PM
gdtrfb42
GX - 1st Gen (2003-2009)
08-05-11 01:49 PM
Quick Reply: service history
