Frozen Navigation Screen Fix DIY
#213
My screen recently stopped working. The buttons on the side worked but nothing on the screen could be touched. My dad and I pulled it out and he used the circuit writer pen on all four traces. Then he accidentally cracked the screen when he for whatever reason placed an exacto knife between the pieces of glass. This broke two of the traces going around the screen. We hooked it back up, but now there's no image on the screen, the climate control button below turns the radio on and off but doesn't turn on the climate control. The temp control buttons no longer work either. Also, the lights for the nav buttons do not light up either. Any ideas why this is messed up now? If I buy a new touch screen, would that fix all of these malfunctions? I hooked everything back up. I even checked the plugs but they only plug into their size outlets.
#214
Made the fix but new issues now!
I fixed the screen, but now the Audio Button and Info Button don't work. I can't go to the Audio Screen or the info screen. Any suggestions?? If I can't fix it I will have to buy a new unit.
#215
#216
I have an issue of my navigation screen not turning on. The touch screen works when it turns on, but it's rare that it would actually turn on. I can't use any of my climate controls when it's like that. The stereo still works though. Anyone have any idea what's going on?
#217
Great info. The take apart was really easy. Rather than take a chance repairing it aftr i took it apart, I bought a new screen for $270.00. Bought it from ebay. It was the identicle screen. It went in easy and the replacement worked perfect. Lexus corporate tried to help and got the dealer repair down to $2100.00...Too much.
#219
Man, I thought I'd never have to do this fix. Ended up doing this fix today, on a damn Sunday. My nav screen stopped responding to touch on Wednesday. But can't be too upset since the fix only cost me $21 (price of circuit writer pen).
But the steps need to be streamlined. You don't need to remove the side brackets and the front components of the nav/radio unit. Once you have the unit out, just remove the front face of the unit to get to the ribbon cable on the nav screen. By not removing the front components, then you don't have to mess with the other ribbon cable connectors. And just like another member stated ...just fix all four traces. Cause its true ...if one trace broke, then the others will break too.
If you lay the unit on its back, the natural tilt on the nav screen provides an excellent angle to apply the "liquid circuit" trace. I put my unit on a pillow to protect the connectors on the back of the unit.
So now my nav screen in my IS350 responds to touch again.
angelita01 (12-15-21)
#221
You might consider just getting the digitizer touch screen vs. the entire screen. I did it after doing the fix 2 times only to have it fail over time in the Texas summer heat. The digitizer only option is pretty easy to install than attempting the repair/circuitwriter method, doesn't require the level of disassembly with the fragile ribbon cables and only cost $60 delivered and it's a brand new part without the problematic design. Works better than the original so far, I'm super happy with it. I just stuck in on top of the existing touchscreen with double stick tape on the edges and plugged it in, done. Check my other posts earlier in this string and posts by others for the guys email address. He also sells the entire screen on ebay but will sell the digitizer separately if you email him.
#223
#224
Prices on ebay seem to range widely -- I've seen reference here to $300 for the LCD screen plus digitizer, but some are now selling these (new) for $175. Can anyone recommend a particular seller that is reputable?
